fuel pump issue
Hi took my erst off the road for the winter first time ive ever done it come to it this week battery was dead so have been charging that i have gone to fire it up and everything is working but it wont fire and i cannot here a buzzing from my fuel pump does anyone have any ideas cheers
i definately have a spark i cant turn tne immobiliser off and have that connected to the fuel pump so im thinking its that
disconnect the wiring from the fuel pump and connect the pump directly to a battery and the pump will buzz if its working, if that works then that leaves you with a relay, wiring or immobilser issue
JK12
33
Apr 26, 2021 12:09 PM
