should i use the amal valve?
Old Mar 4, 2009 | 07:57 PM
B1G_RST's Avatar
B1G_RST
Default should i use the amal valve?
escorts nearly back together, few wee nigghles to look at
who uses the amal valve and who dont,
whats the benfits using/not using the valve,,
cheers
Old Mar 4, 2009 | 08:04 PM
B16CVH's Avatar
B16CVH
I always use them, if it fails my boost drops to half which is good to know!
Old Mar 4, 2009 | 08:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah also if your ECU 'hears' knocking or reads high ACTS it will shut your boost right down to save your engine.
Old Mar 4, 2009 | 11:38 PM
addiction's Avatar
addiction
aint had one on mine for years!!
Old Mar 5, 2009 | 12:22 AM
Chopshop85's Avatar
Chopshop85
I dont use one.
the chances of the amal actually working are slim to none. Ive had 3 that havent worked. The last one used to kill the boost if it went over 6psi!!
Old Mar 5, 2009 | 12:57 AM
ram's Avatar
ram
Has a large member
no anal valve for me
Old Mar 5, 2009 | 07:58 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
dont use mine, car seems to be better without it
Old Mar 5, 2009 | 09:45 AM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Not for me poxy things!
Old Mar 5, 2009 | 10:13 AM
cozmeister's Avatar
cozmeister
More boost Igor!
That's not the valve's fault - the ECU switches the valve's earth to open and close it in order to get rid of excess or dangerous boost in the event that the inlet temp is too high or boost pressure is above the limit of the chip. If the valve isn't connected you only have the actuator's preload setting to determine the amount of boost the turbo makes.
I wouldn't go without one personally, or at least some form of automatic boost control.
Old Mar 5, 2009 | 03:47 PM
JamboRS's Avatar
JamboRS
focus rs 1672
in theory yes but by the time the ecu detects knock and sends the signal to the anal valve its usually too late,been there twice
Old Mar 5, 2009 | 04:18 PM
Dragsteer's Avatar
Dragsteer
I remove it and put manual boost controler, and I think there is boost comming faster after put mbc. someone told me that can be possible because amal is pulsating device ...
but I also go check my fuel mixure on boost before remove amal. I know that in summer amal reducing boost to 0.3 bar , from time to time, so amal isnt bad to have. But if you are sure that you have good conditions (good fuel mixure, normal intake temp) put manual boost controler. I have it in car, nice thing it is.
edit: amal can late and send signal after knock BUT it low down boost and prevent knocking.
Old Mar 5, 2009 | 04:21 PM
Chopshop85's Avatar
Chopshop85
oh right. thats just what i was told by a tuning company.
removed the valve anyways and it seemed to cure the problem, just got a boost controller instead.
Old Mar 5, 2009 | 05:45 PM
B1G_RST's Avatar
B1G_RST
so i unplug it, block of the metering unit pipe and fit my bleed valve between the actuator and turb ?
Old Mar 5, 2009 | 06:05 PM
Dragsteer's Avatar
Dragsteer
I have something like this...works good.
http://cgi.ebay.com/ebaymotors/Turbo...Q5fAccessories
yes, it goes between turbo and wastegate actuator. 10 min job. depends on model, but that from link is very good and boost can be controled from car (you can put it somewhere, under seat...)
Old Mar 6, 2009 | 07:20 AM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
and block off metering unit pipe or leave to air?
Old Mar 7, 2009 | 06:31 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
block it off mate.all my rsts have been to jamsport and he always disconnected them
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
