Stack rev counter again help please
Old Mar 1, 2009 | 06:59 PM
carlo's Avatar
carlo
Default Stack rev counter again help please
I have a stack rev counter how do i configure it to run coil pack i am running it off pin 25 on my ecu.
I have removed the rev counter but it hasnt got a switch or anything like that on it, i dont have the booklet to check.It was peak recall button is it done through that?
Old Mar 1, 2009 | 07:22 PM
Rick's Avatar
Rick
yes, its done throught the button. You have to set it to 2 cylinder mode.
Old Mar 1, 2009 | 07:24 PM
The DIVA's Avatar
The DIVA
Carlo....
Don`t run it off the ecu mate, just put it to one side of the coilpack trigger and set it up for 2 cylinder operation
Old Mar 1, 2009 | 07:25 PM
The DIVA's Avatar
The DIVA
Just noticed you have picked up the trigger at the ecu
I`ll try and dig out a manual, give us a min
Old Mar 1, 2009 | 07:32 PM
carlo's Avatar
carlo
Rob how do you set it to 2 cylinder operation from the switch is there a sequence(sp) also there is a blue wire going into the rev counter i think its from the peak recall switch is that the signal wire that i use to put the wire from the ecu to?
The DIVA's Avatar
The DIVA
Here you go fella, have linked it for you...
http://s2.pegasusautoracing.com/stac...h%20Manual.pdf
Old Mar 1, 2009 | 07:36 PM
carlo's Avatar
carlo
Thanks mate i will get a read
Old Mar 4, 2009 | 08:38 PM
carlo's Avatar
carlo
Still not winning run the signal wire from pin 25 but it didnt work
Old Mar 4, 2009 | 09:15 PM
Ollie.'s Avatar
Ollie.
This will be next to Jtechs in the breaking section!
Old Mar 4, 2009 | 09:26 PM
carlo's Avatar
carlo
Most likley
Old Mar 4, 2009 | 09:29 PM
Ollie.'s Avatar
Ollie.
Matei know where you went wrong... you said nice clean RWD saff, 380hp, decent brakes and suspension and get use out it!!! No fucking fancy engine
Old Mar 4, 2009 | 09:31 PM
carlo's Avatar
carlo
I know mate thing is tho i know if i break it i will just buy another evo or something then back to square one because i cant leave anything alone
Old Mar 4, 2009 | 10:45 PM
The DIVA's Avatar
The DIVA
Just go straight to one side of the coilpack then fella, either one of the outside connections on the 3 pin plug on the coilpack.....then set the counter to 2 cyl and it should be all good
Old Mar 4, 2009 | 11:20 PM
polly_x's Avatar
polly_x
Exactly like Rob said. Run it from a trigger after the ignition Amps. Have the same probs with the VDO Rev counter on Lee's Westy. They need a stronger signal.
Old Mar 5, 2009 | 07:48 AM
carlo's Avatar
carlo
Cool rob i will do that tonight,that means i have to hack into my nice loom
Old Mar 6, 2009 | 08:41 AM
polly_x's Avatar
polly_x
Carlo, dont hack into the Loom!!! Carefully remove one of the pins from the coilpack plug and either crimp a new terminal on with an extra wire to feed your counter or carefully solder another wire onto the existing connector. Refit into plug and hey presto you have a factory looking feed!
Old Mar 6, 2009 | 08:50 AM
OldDan's Avatar
OldDan
Do these work OK running off the Omex wire for tacho?
TPM961
Jan 15, 2018 10:50 AM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Sep 29, 2015 09:06 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
