Morris gets more grunt :-)
Old Mar 1, 2009 | 11:41 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Morris gets more grunt :-)
Just changed the turbo/manifold and injectors on the yellow car and put it on Pectel T2 at the same time, yesterday I mapped it so far up to 1.4 bar tailing off to 1.2 at the top end and now have 331hp and 327ft/lb, it had 260hp previously and ran out of puff at below 7k, now it wants to rev to 8k And the bonus is it has more power everywhere, roll on Combe!!!
Thanks to Wayne/Alex and the guys at Pro Alloy for altering my their previously fabricated alloy pipework to suit
Subaru VF34 roller bearing turbo and new manifold...
Old Mar 1, 2009 | 11:43 AM
Maria.'s Avatar
Maria.
Awwwwwwwww morris!
Old Mar 1, 2009 | 11:44 AM
Luca's Avatar
Luca
Lukesville
Be interested to see the graph M have you one you could show
Old Mar 1, 2009 | 11:48 AM
Martin-Hadland
I haven't finished with it yet but it does come on boost real quick and holds on to the power very well at the top. Should be done tomorrow, I don't know why I'm bothering going any further tbh as it already has more than the 320hp that I had decided was sensible.
Old Mar 1, 2009 | 11:51 AM
Lamb Souvla's Avatar
Lamb Souvla
Excellent stuff Martin, is there a build thread?
You do have a cool garage of cars.
Old Mar 1, 2009 | 11:54 AM
Twellsie's Avatar
Twellsie
is morris the audi engined MG?
Old Mar 1, 2009 | 12:03 PM
Martin-Hadland
There you go..
https://passionford.com/forum/showth...highlight=audi
Morris... (named by Wayne at Pro Alloy!)
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
I'm curious to know what Morris is too.
Old Mar 1, 2009 | 12:10 PM
Alps Pacino's Avatar
Alps Pacino
Good stuff, i have an ibiza cupra running a vf34 was rolling roaded at 351bhp and that goes well and should hopefully be reliable.
Does the mg torue steer badly cause mine is shocking tbh
Old Mar 1, 2009 | 12:14 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Nice power for the boost
Steve.
Old Mar 1, 2009 | 12:15 PM
Martin-Hadland
It didn't before, have not driven it yet. Does yours run equal length driveshafts?
What boost are you using for 350hp?
Old Mar 1, 2009 | 12:21 PM
Alps Pacino
standard drive shafts, so what ever a seat cupra comes with?
Tbh i aint to sure on the boost but 1.9 bar rings a bell, the car is a totally standard 150 motor with the usual bolt ones, vf34 and water injection.
Old Mar 1, 2009 | 12:31 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Alps just look what has to be done to change the turbo lol engine job out so good luck
When marc mapped the ibiza he set boost to 1.7bar so he told me when i owed it
Old Mar 1, 2009 | 12:33 PM
Alps Pacino
Dont be so fucking silly, the engine dont need to be out to change the TURBO but it aint an easy job but i wont be doing it so who cares lol
Old Mar 1, 2009 | 12:34 PM
Martin-Hadland
Cupra's come with a long shaft on the engine side, not good for big power. MGZR's come with unequal shafts too but I sorted that.
Old Mar 1, 2009 | 12:37 PM
Brookesy's Avatar
Brookesy
Whens this at Combe then Martin??
Old Mar 1, 2009 | 12:38 PM
Alps Pacino
Wouldnt that long shaft make the drive shafts on a standard cupra egual lenght?
I aint heard any bad things about people busting that shaft and i know of a few lads with them around the 350bhp mark.
Just out of interest do you do any performance bit for the 20vt motors?
Old Mar 1, 2009 | 12:47 PM
Martin-Hadland
No, when you look at the shafts on a Cupra one is much longer than the other.. By using a solid mounted jack shaft (as pictured) 2 equal length shafts can be used, this helps cut down torque steer.
Old Mar 1, 2009 | 12:50 PM
Alps Pacino
Ah right i get you know so that shaft in the picture isnt a standard fit to a cupra and its something you have modded so you can use equal lenght shafts.
If so could you do it to a my ibiza so that it has equal shafts
Old Mar 1, 2009 | 01:03 PM
Martin-Hadland
It could be done but my picture is a little misleading.. Its a 20V engine but has a Rover gearbox fitted to which I have adapted Rover V6 driveshafts.
Old Mar 1, 2009 | 01:08 PM
Alps Pacino
ye i could see the adaptor plate so guessed you had used a different box. I'm guessing it wouls be all custom 1 off stuff so wouldnt be even close to a reasonable price lol
Old Mar 1, 2009 | 02:40 PM
stevieturbo's Avatar
stevieturbo
C**t
350 is huge HP for a VF34. Normally a TD05 smokes the VF34/35 easily, and spools pretty much the same. And a TD05 wont go much past 350.
That said, it all depends on which rollers etc etc.
A TD05 18G hybrid would be a good upgrade if looking to spend a few quid, or the 20G wheeled one.
Mark at Lateral Performance also sells some fantastic IHI based hybrids although they are a lot pricier than the oil journal TD range of Subaru turbo's
Old Mar 1, 2009 | 04:35 PM
leecavturbo's Avatar
leecavturbo
I'd deffo be running that a little rich even at the expense of a little power due to that short runner manifold ???
t2 got individual cylinder trims?
Old Mar 1, 2009 | 05:28 PM
fezzajsy's Avatar
fezzajsy
Old Mar 1, 2009 | 05:32 PM
Luca's Avatar
Luca
Lukesville
Pretty much cancelled my torque steer out all together!
Its the only way to go with a High HP fwd
Old Mar 1, 2009 | 05:54 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Dont be so fucking silly, the engine dont need to be out to change the engine but it aint an easy job but i wont be doing it so who cares lol
Erm...
Old Mar 1, 2009 | 06:04 PM
Alps Pacino
Originally Posted by Will @ M Developments
Erm...
Fuck off
Old Mar 1, 2009 | 09:25 PM
I thought these engines were poo.
Old Mar 1, 2009 | 09:54 PM
J1mbo's Avatar
J1mbo
B1mbo
moriris is cool !!
why morris over ernie (i think its ernie ) st combe ??
Old Mar 1, 2009 | 09:58 PM
Alps Pacino
What makes you think that? there a cracking motor and easily tuned
Old Mar 1, 2009 | 10:11 PM
Spiky's Avatar
Spiky
when you at combe martin?
some great power front that car
Old Mar 2, 2009 | 06:25 AM
I just got told that the head gaskets always go and heard that the heads need to be torqued down evert few months.
Old Mar 2, 2009 | 07:16 AM
Barry_GTi's Avatar
Barry_GTi
What??? You sure they weren't talking about a 1969 International Tractor??
Old Mar 2, 2009 | 07:39 AM
Porkie's Avatar
Porkie
You know this MG has an Audi 20v Turbp engine and not a K series yes?
Old Mar 2, 2009 | 08:16 AM
Spiky's Avatar
Spiky
i think you know the answer to that
Old Mar 2, 2009 | 08:52 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Should be a right little weapon now.
Ideal trackday toy
Old Mar 2, 2009 | 08:54 AM
Less.'s Avatar
Less.
having a mid life crisis
Cracking car
Rod-Tarry
34
Dec 1, 2007 08:29 PM
Fil
Jul 8, 2006 10:33 PM
!mouse-oxford!
11
Feb 23, 2006 09:42 AM
dvid
May 23, 2005 03:50 PM
Hofajoab
Oct 8, 2004 08:12 AM
