Anyone with a REALLY good knowledge of the Focus alternator?
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Is the charging voltage regulated by the ECU?
Can the alternator run correctly if the warning light is absent from the dash?
Is there a way of running the alternator without either of the above?
Just trying to clear up some urban myths/speculation and get some facts
Yeah, will drop them a PM...
I'm just trying to establish if i can wire round the issue of removing the factory ECU and clocks without having to pay a couple of hundred quid for a race alternator.
I know there is a solution but i'm loathed to just throw money at the problem!
Found this, looks like no, unless they have an olde stylee back up built in;
The BF Falcon uses a new generation 130 amp Mitsubishi alternator, 5R29-10300-AC, known as a smart alternator. It uses a voltage regulator with three terminals: A (or S) terminal, SIG (or RC) terminal and FR (or LI) terminal. The A terminal senses the voltage at the battery, the SIG terminal receives a pulse width modulated (PMW) signal off requency 128 Hz from the ECU to control regulating voltage and the FR terminal sends a signal to the ECU indicating how hard the alternator is working.
The Ford Focus also uses a smart alternator, manufactured by Magneti Marelli or Motorcraft. They use the same regulator plug as the 130 amp Mitsubishi alternator. All of these alternators can be bench tested using a suitable PWM.
The wiring is well known for going faulty aswell,causing a drop in charging voltage.
we change alternaters on focus's all the time.they are rubbish.the alternator is controlled by pcm and told to charge when requested.the smart charge generator in the back is dormant until pcm asks it to charge.normally it packs up and cant work as the request and stop is so frequent.
i would imagine cars could run without a charge light as the alternator has its main lead from battery then the 3 pin plug,1 wire is a fused battery feed,one is signal to and from pcm and the other pin is the light request wire.
hope this helps a litle bit mate as from the amount we have changed and reading up on etis,thats my understanding of 'smart charge' alternators
Hmmm - might start looking at some earlier zetec ones without the 'smart charge'...
I guess nobody has tried disabling the 'smart charge' circuit?
i ran a 1600 zetec se in my ka, had no wiring for the alternator, and that ran fine no issues at all, i should have a pic off one you may be able to get that to work?
The reason i'm keen to do the research on this now is because with the supercharger on, alternator removal isn't easy!
That and the fact i've been caught out before with a race car alternator - we paid £500 for a lightweight alternator on an Evo that didn't charge below 1800rpm... Which meant it kept dying at idle
surely losing the stock ecu will open a world of issues? does it have nothing to do with the abs, immobiliser etc?
are you planning on removing the stock ecu and wiring and using a dig dash and aftermarket management?
Interested in this too on my new project, but thought there might be abs, ps and other electric issues from it.
ABS - don't want as the car is going to be on AP 362 6pots and used for track primarily.
Will have an aftermarket alarm/immobiliser on it as well.
