cossie management with efi inlet
I've also heard the EFI inlet manifold doesnt flow as well as the MFI inlet manifold, but at the end of the day it just means you have to run your turbo harder to make the same power and have a very good IC to keep your charge temps down.
Read the 7th post down by Tony Turbo https://passionford.com/forum/ford-escort-rs-turbo/83295-cossie-management-s1-inlet.html
gadget that post makes interesting reading!seems to thoug the book out of the window in relation to mfi being the better of the two?i`m even more confused now on what to to
Cool....that's the region i want mine in when i do the next build so i can't really help much before then lol! Tbh from what i can tell i don't think it'll hold you back that much using an efi inlet, others have done it so up to you or your tuner?! I used it cos it was easy when i converted to efi (omex) to be honest.
been told efi is crap?????????????
