Getting 2psi of Boost at 5,000 RPM
Old Feb 27, 2009 | 02:05 PM
Shep_Cobain's Avatar
Shep_Cobain
Default Getting 2psi of Boost at 5,000 RPM
So,
Put a turbo my mate had on my ERST...
Got no boost. Mucked about and checked amal valve connections and they are all correct.
Wastegate isnt getting stuck but if i drive in 2nd all the way to 5,000rpm i get like 2psi of boost on my gauge and hear it slightly dump.
Any suggestions?
Old Feb 27, 2009 | 02:10 PM
RS 5tu's Avatar
RS 5tu
how is the actuator?
Old Feb 27, 2009 | 02:19 PM
Stu @ M Developments's Avatar
PassionFords Creator
Somebody has cocked up the wastegate installation by the sound of it.
Old Feb 27, 2009 | 02:23 PM
orion88's Avatar
orion88
yea same here try winding the rod up
did this on my old turbo and the car didnt boost to 0
swopped my actuator and was fine
Old Feb 27, 2009 | 02:41 PM
Shep_Cobain
I did a straight swap from my old turbo to the new one (my mates). The actuator never changed lengths etc.
Old Feb 27, 2009 | 02:56 PM
orion88's Avatar
orion88
try bypassing the amal valve
Old Feb 27, 2009 | 04:25 PM
Shep_Cobain
Old Feb 27, 2009 | 04:37 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Did you have to pull the actuator rod out in order to get it onto the waste gate lever? It's supposed to be mounted with a fair amount of pre-tension.
If that's all fine, you could try removing the pressure hose from the actuator. BUT BE CAREFUL your car will run unlimited boost now. If it boosts, it is most likely the amal valve thats knackered. If it doesn't boost, it's the turbo.
Old Feb 27, 2009 | 04:38 PM
RS 5tu's Avatar
RS 5tu
Originally Posted by SordFish
no but, surely if it was the amal valve the gate would stay shut and boost loads till the exhaust pressure pushes the gate open?
For the few seconds it would take i would say just try bypassing it.
Old Feb 27, 2009 | 05:20 PM
Shep_Cobain
tried to bypass and still no boost.
So i take it the Turbo is fubared?
Old Feb 27, 2009 | 05:42 PM
Shep_Cobain
or should i try twisting the actuator rod?
Old Feb 27, 2009 | 06:59 PM
Shep_Cobain
Old Feb 27, 2009 | 07:07 PM
mart rs's Avatar
mart rs
split hose?
Old Feb 27, 2009 | 07:33 PM
Shep_Cobain
Originally Posted by mart rs
split hose?
no. All checked.
Old Feb 27, 2009 | 08:14 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
are the hoses staying fine like they should
and not collapsing??? are they
Old Feb 27, 2009 | 08:42 PM
mart rs's Avatar
mart rs
the one to the guage?
Old Feb 27, 2009 | 08:46 PM
taz1787's Avatar
taz1787
have you tried a different guage
Old Feb 28, 2009 | 11:39 AM
Shep_Cobain
The lad who gave me the turbo rekons i need to tighten up the actuator rod.
but i cant see it making a difference?
Old Feb 28, 2009 | 12:13 PM
I think its time you stopped letting people play with it who dont know what they are doing to be totally honest mate.
Old Feb 28, 2009 | 12:18 PM
Steven_RW's Avatar
Steven_RW
I agree with that statement.
I also agree where someone asked something along the lines of "When you installed the actuator, the rod has an Eye hole in it and that has the wastegate rod pushed through it. You should have to use proper effort to get the actuator rod over the wastegate arm, if you don't then there is no pre-tension on the wastegate. At the moment everything you are saying sounds like the wastegate is not shut, regardless of you telling us it is
Have u checked that the exhaust elbow is bolted tight to the turbine housing? It could be loose and the eblow has the wastegate penny attached to it. If loose it won't be sealing properly.
The other option would be to pull the pipe off the wastegate and floor it in say 4th, if the boost goes mental or much higher than the 2psi, then there is something wrong with ur boost control system. If you do this, only floor it for a tiny half second to see if the guage rises much further, the car would be unsafe but not for just a .5 second test of boost.
Head up and see one of the pros if you want.
RW
Old Feb 28, 2009 | 12:21 PM
Shep_Cobain
Yeh, sounds like the best plan.
Wheres the best place to send it in mate to get it ready for you to tinker with it?
Its leaking gearbox oil, but at a slow rate. So maybe the seals on the driveshafts.
Fixed idling and leaks. Just gearbox oil and turbo now.
It used to be fine lol. I wish i just had a professional do the work. Ive seriously learnt from my mistakes.
I don't know what im doing and i admit that, but its annoying when a mate says he does and then wants to charge me when he didnt have a fucking clue. Turns out its his first time and he was playing a guessing game!
Old Feb 28, 2009 | 12:30 PM
Shep_Cobain
RW
I'd rather now just take it to a person who knows what their doing now.
Any suggestions?
Old Feb 28, 2009 | 12:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Why dont you just take it to Stu??? Or is he not local?
Old Feb 28, 2009 | 12:56 PM
Shep_Cobain
Yeh, he is.
But i didnt think he did work like that... i know he knows his stuff (big time) but thought he did setups and stuff like that etc
Ill drop him an email and see if he wants to take a look for me.
Cheers.
Old Feb 28, 2009 | 04:36 PM
Steven_RW's Avatar
Steven_RW
I am pretty sure that stu would be happy to look at your car. Sounds like it needs an experienced eye on it and he will more than have that covered!!! If I was your way and in your situ, that is exactly what I would do.
RW
Old Feb 28, 2009 | 04:50 PM
Cheers.
I can tell you exactly whats wrong with it mate, wont take too long.
Pity you canceled the last appointments really, seems you have been messed about since.
Old Feb 28, 2009 | 05:03 PM
TiB's Avatar
TiB
Wastegate arms sit differently from turbo to turbo, the actuator will more than likely need adjusting.
Old Feb 28, 2009 | 05:38 PM
Shep_Cobain
Ok matey, your a star.
Well the reason i cancelled was because of the gear box oil and the bodged up/rush of a job my mate did. Ive sorted this now and got it all back together but still have the garbox leak (which he says is just residue from when it was filled) and the none working turbo.
I can get the car to you anytime matey. Just let me know.
Old Feb 28, 2009 | 06:01 PM
Drop me an e-mail to work on sales@remapping.co.uk and we can book you in mate. Hopefully soon have you mobile again with some boost.
Old Feb 28, 2009 | 07:28 PM
Shep_Cobain
Best thing is if you have a spare hour or whatever to look at it that would be great because i still have the problem of a leaking gearbox to be sorted
I defo want it setting up by you hence the new turbo, intercooler, clutch and fuel pump i got. But the reason i cancelled was because of the state i got it back in.
But if you could look at the car to advise the problem and then i can get it properly booked in for a setup and whatever with you
Old Mar 1, 2009 | 05:22 PM
Shep_Cobain
Just let me know Stu, ta.
Old Mar 1, 2009 | 05:26 PM
I can only advise you email me mate, I dont come on the forums trying to remember what work people may have wanted doing, but if you e-mail me or call me at work then we can go from there regardless if you only want to book one hours labour to test or go for a full setup at £141 which id advise given the adjustments that have likely been made before they gave up and give you the car back with no boost.
Old Mar 1, 2009 | 05:48 PM
Shep_Cobain
Ok dude, ill drop you an email now.
Old Apr 22, 2009 | 10:06 PM
slimwynn's Avatar
slimwynn
did u get your car sorted in the end ???
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
Marino
Sep 12, 2015 11:10 AM
