2.1 Zetec Turbo - Silvertop/Blacktop
Can any help, Silvertop and Blacktop have different conrods but silvertop are chunkier at the top where you need to machine it out to 21mm for the bigger Calibra turbo gudeon pin. A guy at an engineering place says the blacktop one is too thin and may crack once machined out. Any one ever done a ZT 2.1 Blacktop if so how did you go about it? I would prefer a blacktop.
you will deffo need the uprated valve springs i got mine from ian howell,and theres no point putting a good piston on a standard rod .
you can get a rod piston combo from the usa for about Ł600
i run focus wrc rods in mine .
p.s you dont want to bore it out to 2.1 theres no need
I know i need to uprate the valve springs. And i have some C20LET pistons to put in but as above will they work in a blacktop with those weedy rods or shall i do a silver top as they have thicker conrods.
the rod angle in the silver top is pants tho ,im sure you can put them on the black top
are 1.8 and 2.0 silvertop conrods the same?? my mate has a scrap 1.8 (Cracked piston)
Iam going for Piper ST170 uprated springs now I think, only Ł150 and direct replacement.
the springs have a finished height 3mm less than the black top ian has a little shim cnc'd that sits on the stem seal and the spring sits on that.
But thats just it ill try and find a pic of a blacktop rod there a bit thin. And only only have a 19mm gudeon pin by the time its been drilled to 21mm they dont look great witch prompted the engineer to say he didnt think they would last.
JoeyBoyden
Jan 4, 2024 02:36 PM
Rsmat
42
Sep 1, 2015 09:39 PM
