tech question
Old Feb 24, 2009 | 07:53 PM
cossie daz's Avatar
cossie daz
Default tech question
im starting to put my cossie lump back in,on a 200 block on the turbo side at the back of block .there is a screw thread hole just above the sump ,whts it for ???
Old Feb 24, 2009 | 07:55 PM
mechanic28's Avatar
mechanic28
oil breather i would guess
Old Feb 24, 2009 | 07:56 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
does it go towards the block or the gear box?
Old Feb 24, 2009 | 07:59 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Is it the breather bung mate?
cossie daz's Avatar
cossie daz
its near the bell housing and points towards brake servo .its got a threaded connecter in it and very unsure wht it is
Old Feb 24, 2009 | 08:01 PM
cossie daz's Avatar
cossie daz
thats where it is mate .
Old Feb 24, 2009 | 08:04 PM
RWD_cossie_wil
It is an extra port for a breather system, if you don't need it just stick a short bolt in.
Old Feb 24, 2009 | 08:10 PM
cossie daz's Avatar
cossie daz
big thank every one
Old Feb 24, 2009 | 11:25 PM
mark r's Avatar
mark r
a wire is normally fixed there with a screw and a clamp in it but most peeps drill out thread and vent there breather systems back to sump through it by drilling a hole
Old Feb 24, 2009 | 11:28 PM
andrewg's Avatar
andrewg
sure its not in the water jacket where some one has had temp gauge in?
is it horizontal into the block or at an angle into sump?
Old Feb 25, 2009 | 12:28 AM
jon@work's Avatar
jon@work
If it's the hole with the fitting in, as shown below, it's for an aftermarket breather.
If it's the hole slightly above and rearwards without the fitting in, it's for draining coolant from out of the block.
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
