efi conversion problem
Old Feb 24, 2009 | 02:49 PM
RS-Turbo's Avatar
RS-Turbo
Default efi conversion problem
hi i have a problen. after the efi conversion the engine starts normal runs 5 seconds and slowly stops. when is start with bit of more throtle the engine runs on higher idle but only for 5 seconds too.
any idea whast the problem?
thanx for help
Old Feb 24, 2009 | 03:57 PM
orion88's Avatar
orion88
ok is the map sensor plugged in?is there an air leak?
Old Feb 24, 2009 | 04:58 PM
Windle's Avatar
Windle
fuel pump relay wired in? it sounds likes it running of the prime then no signal to kick the pump in! listen under the car whilst it runs see if pump is buzzing?
Old Feb 24, 2009 | 06:18 PM
nigel b's Avatar
nigel b
what fuel pump are you running?
Old Feb 25, 2009 | 10:20 AM
RS-Turbo's Avatar
RS-Turbo
yes the map is in and i have no leaks. when i turn the key the pump runs. its the turbo ke-jet pump.
Old Feb 25, 2009 | 03:22 PM
Windle's Avatar
Windle
do you mean under ignition or cranking?
ignition primes the pump for hgalf a second or so, once the car fires the pump should run constantly, mine did this when i first did my EFI until i ran the wire into the relay. Same as yours ran a few seconds then died
Old Feb 25, 2009 | 06:29 PM
RS-Turbo's Avatar
RS-Turbo
unter ignition the pump runs. when i crank i dont know.
Old Feb 25, 2009 | 09:20 PM
B16CVH's Avatar
B16CVH
Put power directly to the pump from another battery while cranking and see if it runs then.
Old Feb 26, 2009 | 09:42 AM
Windle's Avatar
Windle
what that man said
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
