General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
friends 450 bhp harvey engined focus has a misfire,
fine under 20psi of boost. fine up to 30psi till it gets to running temp.
on p8 ecu,, and same with a L8.
fairly new engine loom all new sensors, had few sets of different plugs in it, new leads cap arm phase etc etc, pectel monitor says all ok.
sounded a bit spluttery up knockhill yesterday
seemed to clear now and again
just seemed to do it under load
sounded like dodgy spark somewhere but you've already changed everything?
whats the plug gaps?
i had jamie's right down to .6mm to stop the splutter on high boost
we've had them down to 23 thou which is about the same
Jimbo its charlies old engine it never done it then & the chip hasnt been changed or that
what about fuel probs ? does it have a decent tank or swirl pot system. we found with the bastos car he had missfire problems because of no swirl pot system ! and the fuel pump was getting gulps of air in cornering
same fuel set up as i had when it was 620 bhp using only one high pressure pump supplied from swirl pot fed by two red tops, and it doesn't need a corner
He said to me today that he found a dodgy pin for the crank sensor i think , might be worth unplugging every sensor one by one & checking all the pins. Bet its something daft
Had something like this once, has it had a new ignition amp? if so there needs to be lots of heat cream between it and the alloy mounting plate. Otherwise the amp over heats and causes a misfire or even shut down!! Its ok when cold, but it would get worse as the motor warmed up! In my case it had me goin for a while!!
Cheers....
i had similar trouble with mine ages ago
in the end i found that a pin in the connector to the coolant temp sensor had slipped down, it was still in the plug but had come off of the sensor itself so wasnt reading any heat
its got to be worth a check.
what about plug leads?
its mint we had break out lead in there checking it all
Cheers....
the amp is on a new ally plate and pretty sure there will be no heat cream!
Whilst the term heat cream is amusing, could you clarify whether there is thermal heat sink paste being used, similar to what computer CPU's use between the heatsink and chip. If you don't the thermal heat sink paste between the ali plate and ignition module will be next to no heat transfer.
can you not just take it out on road when it misfifes stop the data logging and download to laptop and see what its doing?
Originally Posted by andrewg
don't have the shit to do that...
it might be worth you investing in a copy of the IAW Monitor software that Stu sells as it will datalog and scope making it easy to find problems like this. for the value of the engines that you play around with, it's a very small price to pay for full diagnostic facilities
