help?? calling all misfire experts??
Old 23-02-2009, 09:34 PM
andrewg
andrewg's Avatar
Default help?? calling all misfire experts??
friends 450 bhp harvey engined focus has a misfire,
fine under 20psi of boost. fine up to 30psi till it gets to running temp.
on p8 ecu,, and same with a L8.
fairly new engine loom all new sensors, had few sets of different plugs in it, new leads cap arm phase etc etc, pectel monitor says all ok.
Old 23-02-2009, 09:47 PM
westus1
westus1's Avatar
sounded a bit spluttery up knockhill yesterday
seemed to clear now and again
just seemed to do it under load
sounded like dodgy spark somewhere but you've already changed everything?
whats the plug gaps?
i had jamie's right down to .6mm to stop the splutter on high boost
Old 23-02-2009, 09:48 PM
andrewg
andrewg's Avatar
we've had them down to 23 thou which is about the same
Old 23-02-2009, 09:53 PM
J1mbo
B1mbo
J1mbo's Avatar
give the old chap a ring tomorrow andy
maybe its a boost limit in the chip, easily changed
Old 23-02-2009, 09:54 PM
westus1
westus1's Avatar
i seen it yesterday
it seemed to clear sometimes so cant see it being boost limiter
Old 23-02-2009, 09:55 PM
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Bit of a long shot and you've probably done it - but check all the earth straps
Old 23-02-2009, 09:56 PM
J1mbo
B1mbo
J1mbo's Avatar
i seen it yesterday
sorry didnt read your post as said andy give him a bell
Old 23-02-2009, 09:58 PM
carlo
carlo's Avatar
Jimbo its charlies old engine it never done it then & the chip hasnt been changed or that
Old 23-02-2009, 10:00 PM
J1mbo
B1mbo
J1mbo's Avatar
what about fuel probs ? does it have a decent tank or swirl pot system. we found with the bastos car he had missfire problems because of no swirl pot system ! and the fuel pump was getting gulps of air in cornering
andy130
andy130's Avatar
would that make it misfire will?
Old 23-02-2009, 10:02 PM
carlo
carlo's Avatar
Think the tank will be sound it was fine when andy had that focus when it was 618 bhp
Old 23-02-2009, 10:03 PM
andrewg
andrewg's Avatar
same fuel set up as i had when it was 620 bhp using only one high pressure pump supplied from swirl pot fed by two red tops, and it doesn't need a corner
Old 23-02-2009, 10:04 PM
andrewg
andrewg's Avatar
yip even stuck an extra one on the head
Old 23-02-2009, 10:05 PM
andrewg
andrewg's Avatar
even tried a new pump
carlo
carlo's Avatar
Map sensor been swapped andy ? when i was speaking to kenny out the back tonight i forgot to mention it
Old 23-02-2009, 10:07 PM
Luca
Lukesville
Luca's Avatar
New loom sounds like the issue to me.
andrewg
andrewg's Avatar
was a new one we stuck on it, and reads fine on the monitor
Old 23-02-2009, 10:08 PM
jacko
jacko's Avatar
with these cars the way they are that would be verry easy to check
Old 23-02-2009, 10:09 PM
andrewg
andrewg's Avatar
its ran mint on it before, its been on there from new and never gave a problem
carlo
carlo's Avatar
He said to me today that he found a dodgy pin for the crank sensor i think , might be worth unplugging every sensor one by one & checking all the pins. Bet its something daft
Old 23-02-2009, 10:10 PM
andrewg
andrewg's Avatar
would alternator cause interferance/ voltage spike?
Old 23-02-2009, 10:13 PM
Kevin Sharp
Kevin Sharp's Avatar
have you data logged it and downloaded it to see what everythings doing when it misfires, poss voltage drop?
Old 23-02-2009, 10:14 PM
FlashRS
FlashRS's Avatar
Had something like this once, has it had a new ignition amp? if so there needs to be lots of heat cream between it and the alloy mounting plate. Otherwise the amp over heats and causes a misfire or even shut down!! Its ok when cold, but it would get worse as the motor warmed up! In my case it had me goin for a while!!
Cheers....
Old 23-02-2009, 10:15 PM
stu21t
stu21t's Avatar
i had similar trouble with mine ages ago
in the end i found that a pin in the connector to the coolant temp sensor had slipped down, it was still in the plug but had come off of the sensor itself so wasnt reading any heat
its got to be worth a check.
what about plug leads?
Old 23-02-2009, 10:16 PM
andrewg
andrewg's Avatar
nope not tried that
be good to get it on R/R and get a scoope on it to monitor voltage and signals
Old 23-02-2009, 10:18 PM
andrewg
andrewg's Avatar
its mint we had break out lead in there checking it all
Old 23-02-2009, 10:19 PM
andrewg
andrewg's Avatar
Cheers....
the amp is on a new ally plate and pretty sure there will be no heat cream!
Old 23-02-2009, 10:20 PM
Kevin Sharp
can you not just take it out on road when it misfifes stop the data logging and download to laptop and see what its doing?
Old 23-02-2009, 10:23 PM
markk
markk's Avatar
collapsing lifter when the oil viscosity changes, would account for an intermittant missfire.
Old 23-02-2009, 10:28 PM
andrewg
andrewg's Avatar
don't have the shit to do that...
Old 23-02-2009, 10:29 PM
andrewg
andrewg's Avatar
they were new,, doesn't mean they ok thou
Old 23-02-2009, 10:31 PM
jacko
jacko's Avatar
you not use solid ones
Old 23-02-2009, 10:34 PM
andrewg
andrewg's Avatar
not in that engine
Old 24-02-2009, 08:24 AM
Rob
Rob's Avatar
Whilst the term heat cream is amusing, could you clarify whether there is thermal heat sink paste being used, similar to what computer CPU's use between the heatsink and chip. If you don't the thermal heat sink paste between the ali plate and ignition module will be next to no heat transfer.
Rob
Old 24-02-2009, 09:47 AM
Ollie.
Ollie.'s Avatar
Have the injectors been flow checked? Maybe dodgy spray pattern on one?
Old 25-02-2009, 08:42 PM
stu21t
stu21t's Avatar
any joy?
always nice to know of things to check if you get a miss
Old 25-02-2009, 10:16 PM
andrewg
andrewg's Avatar
nope tried another amp and plate tonight from another car
Old 26-02-2009, 05:56 AM
foreigneRS
Testing the future
foreigneRS's Avatar
it might be worth you investing in a copy of the IAW Monitor software that Stu sells as it will datalog and scope making it easy to find problems like this. for the value of the engines that you play around with, it's a very small price to pay for full diagnostic facilities
Old 26-02-2009, 07:19 AM
GUZZLER
GUZZLER's Avatar
get Carlo to take it to AVA
Old 26-02-2009, 07:47 AM
carlo
carlo's Avatar
Quick Reply: help?? calling all misfire experts??
