sparking from the bellhousing
Old 19-02-2009, 12:07 AM
l0ubie
keepin' it ol' skool
l0ubie's Avatar
Default sparking from the bellhousing
right, got the escort running tonight and it runs perfectly until really high revs and then sparks apear from the bellhousing,
looks like an angle grinder is in there, and i dont know why,
doesn't do it till 7k+ revs!!
any ideas?!
Old 19-02-2009, 12:38 AM
whosyadaddy
whosyadaddy's Avatar
Release bearing on it's last legs?
Any other symptoms, grinding noise ect?
Old 19-02-2009, 09:46 AM
l0ubie
l0ubie's Avatar
no nothing!! thats whats really wierd.
nothing happens until about 7k revs, then looks like a catherine wheel in the bell housing
Old 19-02-2009, 12:56 PM
Mark_1
Mark_1's Avatar
stop looking under your car while driving on high revs...
sorted.
does the same thing happen if you put the clutch in and just rev it to 7k while standing still?
I would suggest taking the gearbox out to have a look, you dont want a shattered flywheel at 7k rpms through your feet.
Old 19-02-2009, 01:03 PM
rickbartlett
G911 TTA
rickbartlett's Avatar
inside bell housing or on it?
Old 19-02-2009, 04:11 PM
l0ubie
l0ubie's Avatar
inside!!!
haha mark!!
i dont think it does it when the clutch is to floor.
Old 19-02-2009, 04:19 PM
SteveH
SteveH's Avatar
How can you see it? is there a hole in the bellhousing or something
Old 19-02-2009, 04:49 PM
Rich_w
Proven Legendary Status
Rich_w's Avatar
Clutch has given up.
Replace.
Old 19-02-2009, 04:57 PM
sortedsaff
sortedsaff's Avatar
clutch aint given up. . Sparks were coming up on the left side of the carb. And if you look underneath you can see its lighting the whole lot up
Old 19-02-2009, 05:10 PM
rst in breaking
rst in breaking's Avatar
have you fitted a new clutch? id be looking at popping the boxing out and looking to be sure what the problem is as you dont want sparks up near carb causing a fire
Old 19-02-2009, 05:12 PM
orion_crazy_carl
orion=mini saff
orion_crazy_carl's Avatar
could be the starter motor or the flywheel touching the bell housing!
Old 19-02-2009, 05:29 PM
.Pete.
mk6 Escort Cab
.Pete.'s Avatar
why are you revving upto 7000?
Old 19-02-2009, 05:32 PM
steves24V's
steves24V's's Avatar
That's what i was thinking, Its sparking cause it's trying to tell you to stop!!!
Old 19-02-2009, 05:54 PM
malcs-escort-cos
malcs-escort-cos's Avatar
x2 to that,but it ant rite youll have to drop the box,before something really bad happens
Old 19-02-2009, 11:01 PM
l0ubie
l0ubie's Avatar
yea i think this might be the prob!
7k? aint nothing, its a crossflow will rev till well past 8!!
Old 19-02-2009, 11:19 PM
andysfatrs
andysfatrs's Avatar
if it doesn't do it when the clutch is pressed then surely its clutch related, how old is the clutch?
possibly worn to the rivets and starting to wear them?
Old 19-02-2009, 11:30 PM
l0ubie
l0ubie's Avatar
its a brand new clutch, probably done 300miles!
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
IainRS1700T
25-09-2015 06:44 AM
krypton
23-09-2015 07:29 PM
pabloXR
21-09-2015 12:42 PM
Quick Reply: sparking from the bellhousing
