rst/cosworth hybrid distributor??
Old Nov 27, 2004 | 01:05 PM
Paddy rst's Avatar
Paddy rst
Default rst/cosworth hybrid distributor??
when using a rst/cosworth hybrid distributor for cos management on a rst, how would you set the distributor up before tightening the 2 bolts up?? do u have to get a timing light on the bottom pulley 12 degrees like when setting up on normal ke-jet system?? or is that what the crank sensor does??
also do the 2 distributors have to be welded together at a certain positions to each other??
,or can they just be welded together without having them at certain positions to each other???
cheers Paddy..
Old Nov 27, 2004 | 03:21 PM
IANS2RST's Avatar
IANS2RST
use a multimeter on the cap to tell when the rotor arm makes contact with number 1 with the timing mark on the bottom pulley aligned to the appropriate mark on the lower timing cover.
not 100% accurate but should be close enough
TPM961
Jan 15, 2018 10:50 AM
steve.rst
Mar 15, 2016 08:01 AM
20/20 vision
Sep 29, 2015 11:27 AM
dms04
Sep 11, 2015 01:57 PM
Sjieter
Aug 5, 2015 09:47 PM
