problem with my lads fiesta turbo
Old Nov 26, 2004 | 06:39 PM
rsjp's Avatar
rsjp
Default problem with my lads fiesta turbo
i need some help with a fiesta turbo ,keeps chucking smoke out exhaust ,just had a new turbo ,done the valve stem seals ,breather is all clear , thought it was crank case pressure ,just need some more things to try before the engine comes out and stripped
cheers in advance
jp
Old Nov 26, 2004 | 06:47 PM
EvilFranky's Avatar
EvilFranky
What colour is the smoke?
When is it happening? All the time? On boost? etc...
Old Nov 26, 2004 | 06:48 PM
CozzyBrom's Avatar
CozzyBrom
sorry mate
crank case presure it sounds like
Old Nov 26, 2004 | 06:50 PM
mattbibs's Avatar
mattbibs
you've mentioned all obvious points. mine was doing the same and afriad it is too much pressure in the crankcase!
does it smoke out of the breather on boost? mine did. advice is to strip it down now before it goes bang like mine did!
Old Nov 26, 2004 | 06:53 PM
Brasso's Avatar
Brasso
Is the hose to the map sensor connected?? Mine pooped off once and I thought I'd fooked the engine because of all the smoke! It was runnin slightly rich!!
The rings and headgasket are gone now tho!
Hope it aint too serious.
Old Nov 26, 2004 | 07:26 PM
nigel b's Avatar
nigel b
i used to have loads of whiteish smoke when mine was cold
when it was warm never smoked
got a TT breather and been ok since(6 years)
Old Nov 26, 2004 | 08:29 PM
Alvyn's Avatar
Alvyn
Originally Posted by YUM360
Have you checked the oil return pipe????
as Dave has said check this 1st as it is common on t2's that the return pipe gets clogged up so oil builts up inside pipe and goes back into the turbo which will cause smoke out the exhaust. (that is if your using the same return pipe) failing that and everything else is checked then
JoeyBoyden
Jan 4, 2024 02:36 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
turbobill
Aug 1, 2015 08:55 PM
