Lifeline Fire and Safety Extinguishers
We are please to announced we are now selling LifeLine Fire extinguishers
After reading many posts regarding underbonnet fires destroying peoples' pride and joy I think it would be a good idea to promote car safety equipment as well as the normal go faster goodies as we have got a lot of money tied up in these cars
I know these products from Lifeline are more expensive than the 'Halfords' type extinguisher, but these are proper car extinguishers meant for oil and petrol fires and are also used in WRC cars.
We will run a group buy on the handheld extinguishers but the full range of products are available from us at discounted prices
please have a look here - http://www.lifeline-fire.co.uk/ and if you are interested in any other product please ask for a quote
Some video's of the products in action
http://www.lifeline-fire.co.uk/fires...os.asp#automat
FIRE MARSHAL SYSTEMS
Fire Marshal Systems are mechanical in operation being activated by strategically placed pull cables. The fire marshal valve is a high quality hand held commercial valve that has been modified by Lifeline to allow total discharge and fitting of pull cables.
101-225-001 2.25ltr Club Fire Marshal -
A superb entry-level Mechanical plumbed in extinguisher kit offering the same legendary quality as found in all Lifeline systems.
Hand Held Fire Extinguishers
Lifeline offers a full range of hand held extinguishers to suit all budgets and motorsport applications. The types of extinguishant offered are
All Lifeline Hand Held Extinguishers are refillable and should be serviced every two years.
201-100-001 1.0ltr AFFF Hand Held
Extinguisher ideal for your road car, trailer, caravan or workshop. This extinguisher is not approved for use in motorsport.
201-100-002 1.75ltr AFFF Hand Held
Extinguisher for national rallying or pre 31/12/60 historic racing
201-100-003 2.4ltr AFFF
Hand Held Extinguisher for international rallying
201-100-004 2.4ltr AFFF Hand Held
Extinguisher for international rallying but fitted with a flexible dip tube so it can be operated on its side or even upside down.
204-100-005 2.4ltr AFFF Hand Held Extinguisher
As per LLH004 but with a slimline cylinder to allow greater flexibility when packaging within the confines of the modern competition vehicle with a flexible clip tube.
Belt Mounted Extinguisher
Ideal for pit personnel these belt mounted extinguishers will allow you to fight small fires quickly and safely using either 0.7Kg of Monex BC powder or 0.6 Ltr of AFFF alcohol additive foam for A, B & C Fires.
The specially designed holster allows for fast easy access but will ensure the extinguisher remains securely held at all other times.
201-100-006 0.7Kg Monex BC Powder Extinguisher
201-100-007 0.6Ltr AFFF Alcohol Foam ABC Extinguisher
The latest generation of Lifeline hand held extinguisher now use the highly efficient gaseous extinguishant ZERO 360. Designed specifically for the rigours of motorsport being able to operate in any orientation. Available in two sizes 1.0 and 2.0Kg.
203-100-001 1.0kg ZERO 360 Hand Held
203-100-002 2.0Kg ZERO 360 Hand Held
If we could get some feedback on what system people would be interested in (i.e handheld/plumbed in nozzels etc) for a group buy I will get prices sorted out ASAP
I think the handheld range would be good as then you could move it from car to car, use it in the garage or if find somebody elses car on fire and feel like a good samaritan you could use it then also
These products are also refillable.
FIRE MARSHAL SYSTEMS Fire Marshal Systems are mechanical in operation being activated by strategically placed pull cables. The fire marshal valve is a high quality hand held commercial valve that has been modified by Lifeline to allow total discharge and fitting of pull cables.
- ZERO 360 Gas
- AFFF Foam (Aqueous Film Forming Foam)
- ABC Powder
- Monex BC Powder
Belt Mounted Extinguisher Ideal for pit personnel these belt mounted extinguishers will allow you to fight small fires quickly and safely using either 0.7Kg of Monex BC powder or 0.6 Ltr of AFFF alcohol additive foam for A, B & C Fires.
This is the best thing you will ever spend your money on
My 500 set on fire under the bonnet at croft last year and if i hadnt got an extinguisher in the car then it wouldnt be in my garage now
,,,,,,,TRUST ME PEOPLE YOU WONT KNOW THE VALUE OF THESE UNTIL YOU NEED IT ,,,
Off topic again....its a free bump though
I was the one who rebuilt Hydn's mk2 Golf vr6 engine off there, if you had seen the thread? Its a nice and relaxed site though aint it
DixieTheKid
11
Jun 6, 2020 11:20 AM
Bailes1992
Sep 19, 2015 02:17 PM
DixieTheKid
Sep 14, 2015 09:04 PM
