Auto Glym HD Wax
Just thought i'd share my experiance with this new wax from AG,
I used to use meguires, tech wax followed by mirror glaze and i got a finish that i was very happy with, then the AG rep came in my work saying he had a couple of tubs of this new wax that wasn't out yet, the High Definition Wax. So i thought i'll try it as the sales pitch was awesome! lol
Tried it on my mums car first (which isnt as kept as my own) and f*^k me!
So i done my FRS and what a finish!
Better than meguires in my opinion,which i didnt think could be possible.
Now i use Auto Glym Ultra Deep Shine followed by HD Wax, finish is perfect and last for ages, not difficult to use either and comes with two soft sponge applicators and a really soft plush micro fibre cloth.
Whole car uses very little wax so i think the tub will last a while.
Well worth a buy!
Well worth a buy!
I used gold class but i didnt think much of it to be honest,the tech wax is far better.i threw my gold class out lol
personally i'd use tech wax to get the paintwork how you want it then HD wax to finish and seal it.
No problem,I used to be a car valeter and I also have OCD! lol so i enjoy sharing my views with other like minded people (read fanatical fannys lol)
Just been looking on ebay for it and you can get it for about £25 plus a few quid postage
Tub looks tiny though
might need to get some as ive used auto glym on all my cars for years
Gave it a good clean, followed by a complete clay with the Bilt Hamber Auto-Clay. Coat of Autoglym Extra Gloss (some cars may need a polish layer like SRP or an equivalent first) and then it was on with the High Def. Remember to clean the surface after every stage (something like Megs QD) Was done 2 days before Ford Fair last year and has not been re-waxed since.
It just gets a simple wash with tap-water, then a quick QD to dry and remove any possible water-marks. Still shines and beads, even now.
As said it the preperation that is key,i'm sure white would still take a good shine if its polished properly first.
Tub isn't that small and a whole car hardly uses any so it does last.
I did my FRS before fast ford at crail end of last year,
Full de-grime with meguires quick clay kit,
then a polish with meguires cleaner wax,
two coats with meguires tech wax,
a coat of auto glym extra gloss protection,
meguires quick detailer
then 7 coats of auto glym HD wax lol (yes seven!)
Took me a whole week of evenings to do but fcuk me it was worth it lol
White is a difficult colour to achieve a deep shine on (as is silver), but a wax won't do it anyway - the gloss levels on a car's paint is 95% down to the preparation work anyway (as a few others have hinted at already).
People expect far too much from a wax, and I'm talking about a pure canauba wax here like the AG HD, not 'cleaner waxes' or 'All in one' products like megs tech wax. A [product like HD is to purely to protect the finish you've achieved with the claying and polishing stages. It won't, in itself, provide any 'shine' as such. Think of it like varnishing an old rough table:- if you sand down the table so it's perfectly smooth, then apply a varnish (even a cheap one), you'll get a great finish, but if you don't smooth it down and prepare it properly, then you can apply as much varnish as you want, it won't ever shine properly. Same sort of thing with car waxes, the best deep wet look glosses are all down to what went on the paint before the wax
Also, each to their own, but 7 layers of wax is overkill imo. and you will run into the law of dimishing returns after about 3 and are wasting time and product unnecessarily. Also, a pure canauba wax needs time to 'gas off' after application when it releases the solvents, so when multiple layers of wax are to be added, you need to leave approx a few hours between applications. This varies from product to product and some synthetic sealants can be layered almost straight away, but for a product like HD wax, personally I'd be allowing about a couple of hours between each layer. Loads of info on this kind of thing over on Detailing World
Yep, done a whole Focus ST225 in Moondust Silver with the High Def. Preparation is the key. I taught the owner whilst doing it. Done over 4 evenings in work (about 14 hours in total).
If you QD a car between all stages, then it minimises the risk of imperfections (scratches, swirls, etc...). A prime example is with the "sealer" stage. If you have any polish residue, a sealer (like AG Extra Gloss) will seal these in until it physically wears off. Same with the wax. If there is some sealer residue that has been missed, a wax will go over it and possibly "react" or smear. A wipe over with QD will remove any of this. Think of it as a panel wipe that you would use if you were painting.
Even when simply washing a car, if you live in a hard-water area, wash the car and then either spray a light mist of QD over the car before drying (acts as a water repellant) or QD once dried to remove water marks.
Thanks Ian for youre reply
.Only had the new AG HD wax in my hand yesterday but didnt buy it.I'll get it when the weather warms up a bit and follow the guide you posted above
.Thanks again,Micky
.Thanks again,Micky
You are using a "cleaner", then a polish, then a wax by using the Megs 3-stage system. You then seem to be adding a "all-in-one" wax afterwards followed by the HD.
If you were getting a dull finish with the AG Super Resin, then you were not allowing sufficient time for the SRP to apply. The SRP is a "filler" polish in the fact that it will mask minor marks and swirls. You would ideally "seal" this afterwards with something like AG Extra Gloss or similar before applying the HD Wax as that would give the HD something to adhere to better.
Why use it with all of the above?
Like you I am totally puzzled by a report of AG SRP 'dulling' the finish? Far too many people dismiss Super Res purely by using it incorrectly. I recently wrote a lengthy 'wiki' article on the correct use of it for the Pumapeople site, and used correctly, it's regarded (even by the hardcore detailing bods like myself over on Detailing World) as being one of the best hand applied All in one products and is also one of the best for filling and masking minor swirling on paintwork. But it does need to be worked in properly, just wiping onto the paint (and often way too much), letting it dry and buffing off will produce loads of dust and won't really do anything other than bead water for a few days. Mind you, AG don't help matters by basically saying just that on the instructions.
Adam Graham
Sep 6, 2015 06:04 AM
