Breather system fitting?
Old Jan 29, 2009 | 05:31 PM
WongRS's Avatar
WongRS
Default Breather system fitting?
Has there been a thread/guide done on here about this, i did a quick search but didn't find much.
Just basically wanting to know where the pipes go/come from, i take it one from the standard breather pipe (under inlet manifold?) and i know one come from the back of the rocker cover, where do the other 2 go, or is 1 just a drain?
Cheers!
Old Jan 29, 2009 | 05:40 PM
big mac's Avatar
big mac
1 is a breather so just to atmosphere and the other return to the sump
Old Jan 29, 2009 | 05:45 PM
WongRS's Avatar
WongRS
Cool, thanks. Does that have to bo drilled into the sump, can i not just put that one to atmosphere too?
Old Jan 29, 2009 | 05:51 PM
big mac's Avatar
big mac
turbo side of the block mate there is a bung remove this and you need an adapter
Old Jan 29, 2009 | 05:54 PM
WongRS's Avatar
WongRS
Cool, Where can i get an adaptor from?
Cheers buddy
Old Jan 29, 2009 | 06:05 PM
WongRS's Avatar
WongRS
Is that the bung we are talking about?
Old Jan 29, 2009 | 06:22 PM
philram's Avatar
philram
Mulechild
on a 2wd its on that side, but on the bottom edge of the block facing up towards the bonnet.. bailey sell the adaptors
Old Jan 29, 2009 | 06:23 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i think thats the coolant bung.
try a bit lower,
and get a better pic!
Old Jan 29, 2009 | 06:25 PM
big mac's Avatar
big mac
no mate further down that is a water drain!!! you can get the adaptor from bailey mate
Old Jan 30, 2009 | 05:06 PM
WongRS's Avatar
WongRS
Cool, will go have another look, and get another pic!
Just to make sure before i do anything
Old Jan 30, 2009 | 05:24 PM
rinus_2005's Avatar
rinus_2005
The oilreturn under the turbo, altough people say just a screw-on jobbie isn't enough. And you should have pipe on it wich go's down into the sump under the oil level to prevent oil getting trapped in the separator.
The bigger outlet on the separator is the vent. For that fit a big hose long enough down along the chassis rail to the bottom of the car. ( i presume your talking the bailey style oil separator? )
succes, Rinus
Old Jan 30, 2009 | 05:28 PM
LHD220Turbo's Avatar
LHD220Turbo
this might help, this is how i did mine - i removed all traces of the standard system
Old Jan 30, 2009 | 05:30 PM
WongRS's Avatar
WongRS
doesn't look like mines even got that hole?!
What the frig is that thing?
and whats this, oil return for turbo?
Old Jan 30, 2009 | 05:32 PM
WongRS's Avatar
WongRS
Thats very helpful, thanks!
I know where 3 of the pipes go now! just need to figure out where this oil return on the turbo side is and i am there!
Oh, and how do you attatch the tank to the car?!
Old Jan 30, 2009 | 05:41 PM
Twellsie's Avatar
Twellsie
try removing the p clip on the wire in the pic
LHD220Turbo
here you go; just done a bit of editing
Old Jan 30, 2009 | 05:44 PM
LHD220Turbo
Rinus 2005's picture is the best picture which shows it.
remember from factory it will have a bung/bolt in it, you need to remove the bolt and get an adapter as Rinus 2005 has got!
EDIT - please take the block out and get it acid dipped and painted, the rust looks awful!
Old Jan 30, 2009 | 05:51 PM
JTECH James
Passion for Fords!
yes, its under the knock sensor wiring clip,
i have an adaptor if you need one.
Old Jan 30, 2009 | 06:00 PM
WongRS's Avatar
WongRS
yay, that's the one i take it?
PM on its way, Jtech!
Old Jan 30, 2009 | 06:05 PM
Twellsie's Avatar
Twellsie
thats the one dude
rinus_2005's Avatar
rinus_2005
Thanks, but it's not my engine. Got the pic from some threat of passion ford. ( want post the link, but i cant find anymore )
Here is a pic of a different setup. And saves drilling the rocker cover. Breath from both sides and return as pictured. ( i'm thinking of doing it this way with next cossie project )
Old Jan 30, 2009 | 06:15 PM
big mac's Avatar
big mac
hope your gona clean that block up while your there !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 30, 2009 | 06:17 PM
WongRS's Avatar
WongRS
Good god no!
Cant see it when the heads back on, and it like a ball ache to do, so i cant be arsed! lol
God i am lazy!
Old Jan 30, 2009 | 06:48 PM
LHD220Turbo
Rinus 2005 - yes its better to return below oil level
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
marky_g
Aug 15, 2015 10:43 AM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
