Wall mounted tv brackets
Old Jan 27, 2009 | 11:56 PM
JonnyBravo's Avatar
JonnyBravo
Default Wall mounted tv brackets
The time has come where I'm finally brave enough to hang my tv on the wall, I've through ebay and there are LOADS !
I refuse to buy a cheap one to hang a £1500 tv off but I was hoping someone could advise me something suitable.
The TV is a 40" Sony Bravia, I've foudn this on ebay which although isn't a genuine Sony product does sound good :
http://cgi.ebay.co.uk/SONY-KDL-40W45...1%7C240%3A1318
I need it by the weekend really so if anyone knows of one I can just go and collect for similar money I'd rather do that
Old Jan 27, 2009 | 11:58 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I bought one off eBay for 18 quid for my 42" samsung, been there for about 6 months now without any issues
Old Jan 28, 2009 | 12:04 AM
JonnyBravo's Avatar
JonnyBravo
Interesting, I'm sure there all ok, I'd just never forgive myself if I came home to find it on the floor in pieces !
Whats the build quality like on yours and how is it fixed to the wall and the tv ?
Any links ?
Old Jan 28, 2009 | 12:06 AM
JonnyBravo's Avatar
JonnyBravo
http://cgi.ebay.co.uk/Plasma-LCD-TV-...1%7C240%3A1308
Old Jan 28, 2009 | 12:52 AM
thebigyin's Avatar
thebigyin
ive had expensive brackets and cheap brackets, they are virtually identical,the only way youre telly will be on the floor is if you make an arse of fitting it! not down to the bracket.
Old Jan 28, 2009 | 06:43 AM
Twellsie's Avatar
Twellsie
as said above, its not the brackets that are the issue, its how the brackets are attached to the wall
Old Jan 28, 2009 | 08:04 AM
999's Avatar
999
i used a omni mount, mine hasnt fallen off yet anyway lol, was quite easy to fit and lock into place, easily removed if need be or can be locked in place with a small padlock
Old Jan 28, 2009 | 08:30 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the wall isn't the issue, the expensive one i've got for my 50" uses 6 M12 rawbolts to secure it to the brickwork, plenty hefty enoguh, but it's the little tiddly screws they expect you to botl into the back of the telly that worry me
on the other hand, my 42" is held to the wall with 10 M8 rawbolts, just to be sure
Old Jan 28, 2009 | 08:34 AM
JonnyBravo's Avatar
JonnyBravo
Ordered one of the cheaper ones, after looking through their feedback there I'd like to think it will be fine.
Did they come supplied with the wall fixings or did you sort your own out Dojj
Old Jan 28, 2009 | 09:14 AM
RichieST's Avatar
RichieST
I bought one to hang my telly on the wall in my new house, until I realised that every fooking wall is made out of plasterboard Doh
Old Jan 28, 2009 | 09:16 AM
Phil's Avatar
Phil
Jeebus
Mine came with huge 13mm (?) bolts about a brick depth long! I had to get the SDS drill out to fit them and watch out incase it went through the kitchen tiles on the other side of the wall . I tried hanging off the mount first and there is no way it is budging!
Old Jan 28, 2009 | 09:34 AM
JonnyBravo's Avatar
JonnyBravo
Same here so I'm moving my room round so I can hang it off the outer wall which is breeze block
Old Jan 28, 2009 | 09:49 AM
dojj's Avatar
dojj
the more expensive one came with about 500 different nuts and bolts and washers to fit to the back of the telly in virtually every conciable depth, thread and head size, but you wil need to get your own wall fixings
here's a tip, figure out where you want to put the bracket, put some lines on the wall, then put a hole in the corner first before you start to level everything up make sure it's not on the piss
the priceier ones also have individual either side adjustabilitym, whereas the cheap ones just have a fixed braket
mine is also lockable so you can' pinch the telly off the wall
Old Jan 28, 2009 | 09:52 AM
JonnyBravo's Avatar
JonnyBravo
Thanks again Dojj, good info there
Old Jan 28, 2009 | 09:54 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Mr Bravo.....check here dude....loads to choose from very reasonable prices too...
http://www.vivomounts.co.uk/
Old Jan 28, 2009 | 10:02 AM
JonnyBravo's Avatar
JonnyBravo
Thats what I have ordered just through ebay
Cheers mate
Old Jan 28, 2009 | 12:13 PM
slim20012's Avatar
slim20012
i cant find a mount for the chepo tv in the bedroom its an Onn OLCD3201 returns nothing on ebay or http://www.tv-wall-brackets.co.uk/onn/32_inch/
anyone know any other cheap places
Old Jan 28, 2009 | 12:24 PM
studabear's Avatar
studabear
I've only had 1 issue with a universal bracket, was supposed to fit 40"+ tv's, when the arms were bolted to the 47" tv the wall plate fitted in between them, so we cut the wall plate in half and mounted the 2 halfs 6" apart on the wall and put 6 screws per plate instead of the 8 screws for the whole plate in 1 piece
1 year on and all is good, we even used the same method when we mounted it in the new house
Old Jan 28, 2009 | 04:33 PM
foreigneRS's Avatar
foreigneRS
Testing the future
probably 8mm bolts that have a 13mm head
Old Jan 28, 2009 | 04:57 PM
steves24V's's Avatar
steves24V's
I've got one excitly the same as your first link but for a 50" and i only paid about £20 for it. It came with a great selction of screws for fixing to the tv and 6 bolts for the wall but i put 8 in mine just to be sure. looks well made and been up for about 4 months.
Old Jan 28, 2009 | 06:03 PM
snoopaloopa's Avatar
snoopaloopa
I'm pretty sure 1 wall plug/coach screw can take in excess of 400kg so as has already been said, its not the fixings its how you fix them
Old Jan 28, 2009 | 07:49 PM
Stu.H's Avatar
Stu.H
I bought one from Empire Direct for £40, would take up to 63" telly.
Came with all bolts (mossive things), fixed to the wall with 8 bolts, and my 50" kinda hooks on this ledge that is attached to the wall.
Ive got confidence you could prolly nearly hang a car on the wall LOL
Old Jan 28, 2009 | 11:53 PM
Daveysaff's Avatar
Daveysaff
http://myworld.ebay.co.uk/the_mount_shop
thats where mine came from. Came with 8 massive bolts and loads of different fasteners and wall plugs and stuff. Went up dead easy and never had any issues with it
Quality is pretty good I reckon, came painted silver with stainless bolts holding the tilty bits together with good nylocs on and a little handwheel adjuster for fine tuning the tilt
Old Jan 29, 2009 | 03:38 AM
nellrodd's Avatar
nellrodd
Was pooping it for days after hanging mine on the wall, expected to come home and find it on the floor with half the wall still attached, but thats 4 months and no probs.... thankfully!!!
Old Jan 30, 2009 | 09:30 PM
cjwood555's Avatar
cjwood555
For a posh one try Unicol - no good for boarded walls though as you can't get enough fixings in - unless you drill more holes.
Unless it's an insanely heavy tv you wont have any problems with pb walls so long as you get a good 14+ fixings in Ok so it's not ideal, but it does the job and saves a lot of hassle.
Chris (who used to put them up for a living and generally tried to avoid the above but has resorted to it on occasion!)
Old Jan 30, 2009 | 09:40 PM
kellyalfie's Avatar
kellyalfie
bought ours from richer sounds to hang 43 pioneer on double plasterboard still up their 3 years on
Old Jan 31, 2009 | 07:49 AM
dojj's Avatar
dojj
this is the one i got
http://www.currys.co.uk/martprd/stor...5&category_oid=
but i didn't pay that much for it
you can see the small locking tabs on the top fixings, pop a small bolt through it and it's never coming out
goo little mod to stop it from being bounced off the wall too
bolt the back ot the wall
bolt the 2 hangers to the telly
clip it on
lock in place
easy
Old Jan 31, 2009 | 07:56 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
All 3 of mine came from Ebay, username 'trytomauctions' or 'trytom' I think. He's absolutely spot on
Old Jan 31, 2009 | 08:23 AM
Ginge !'s Avatar
Ginge !
just finding my feet
mines from ebay too, the local tv show was trying to sell me saying "avoid these cheep ebay jobs" IT WAS THE SAME FUCKING ONE AS I GOT FROM THERE but he was asking for 150 quid for it,, i paied 18 including the posting !!!!
i went for a ebay one,,, mainly cause i have insurance i pay each year that covers accidental damage,, and so would get the latest plasma anyway should it fall off the wall
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
martynhomer01
Oct 1, 2015 12:05 AM
DavidK
Sep 27, 2015 02:55 PM
