4x4 cossie engine using 2wd sump
Old Jan 27, 2009 | 07:24 PM
coswurv's Avatar
coswurv
Default 4x4 cossie engine using 2wd sump
anyone done this, if so did you retain the 4x4 oil pump and pick up pipe, as ive measured it and it seems that the pick up pipe is very close to the bottom of the sump, obviously i dont want to starve the lump of oil, any info much appreciated
Old Jan 27, 2009 | 07:30 PM
col cos1's Avatar
col cos1
people bend the pick up pipe i think
Old Jan 27, 2009 | 07:34 PM
blacky.'s Avatar
blacky.
why not just leave the 4x4 sump on or is the motor going in a 2wd
Old Jan 27, 2009 | 07:42 PM
coswurv's Avatar
coswurv
yeah its going into a project car where i need to use the 2wd sump, so bending the pick up pipe is an ok thing to do,
Old Jan 27, 2009 | 07:48 PM
blacky.'s Avatar
blacky.
ye just dont go mad with it
iv seen a kit car running 4x4 useing a 2wd sump it had the front diff mouned infront of the motor
Old Jan 27, 2009 | 07:56 PM
coswurv's Avatar
coswurv
anybody else got any info on how much to bend it by etc
Old Jan 27, 2009 | 08:12 PM
PGT's Avatar
PGT
mine is like that although i didn't think to measure it! not had any problems though
Old Jan 27, 2009 | 08:25 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
my saff one was modded for 2wd sump too. there was deffo a "how to" on here but sorry cant think who from
Old Jan 27, 2009 | 08:29 PM
coswurv's Avatar
coswurv
so yours is a 200 block 4x4 engine with 4x4 oil pump and pick up etc just with the 2wd sump bolted on ?, did u use a 2wd sump gasket set or did you just stick it on like the way the 4x4's are done
Old Jan 27, 2009 | 10:14 PM
westus1's Avatar
westus1
use a 2wd sump gasket,
and just bend the pick up pipe up a few mm
done it this way a few times and never had any bother
as for he kit car blacky was talking about
thats the same kinda set up that andy gallacher has on his focus
Old Jan 27, 2009 | 11:08 PM
lee2cossies's Avatar
lee2cossies
Cant you use a 4x4 pump with a 2wd pick up?
Old Jan 27, 2009 | 11:39 PM
PGT's Avatar
PGT
just stock 2wd gasket.
Old Jan 28, 2009 | 07:54 AM
coswurv's Avatar
coswurv
cheers for the reply's everyone been a great help, just a few tweeks and saves me buying a replacement.
Old Jan 28, 2009 | 08:33 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the 4wd pick up is bent to clear the intermediate shaft so it's a different shape
you can use what you have and just bolt the 2wd sump onto it, the peole who do the 24V swap on their xr's and stuff do it the other way around where you HAVE to get the 4wd pick up otherwise it won't fit
also, don't forget that by bending it, make sure you don't loosen the seal on teh pipe to the bit that bolts up onto the pump as if the whole thing falls off your engine will be sucking up oily air only, which is going to be much much worse
Old Jan 28, 2009 | 08:36 AM
coswurv's Avatar
coswurv
So i can just unbolt my 4x4 sump fit a 2wd sump with relevant gaskets and bolt it back up, with no clearance problems regarding the pick up pipe being to close to the bottom of the sump ?
RUBY123
Oct 22, 2023 12:04 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
