Whats to be done to fit this
onto a 2wd?is it a case of swapping it into the 2wd casing?
http://cgi.ebay.co.uk/QUAIFE-ATB-DIF...1%7C240%3A1318
It will bolt straight into your 2wd beam, a small spacer will be needed in one of the top fixing bolts. You will also need 4x4 shafts and the corresponding splined ends, your bearing carriers and drive flanges will be ok to use.
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
