urgent help needed
Old Jan 25, 2009 | 01:30 PM
SWIFTY's Avatar
SWIFTY
Default urgent help needed
just put my engine back in but will not start
it has no spark someone has told me it could be my crank sensor
so need to no asap how to test it thanks.
Old Jan 25, 2009 | 01:36 PM
mechanic28's Avatar
mechanic28
have u a knock sensor fitted?If so make sure you have not connected the crank/knock sensor the wrong way round!or it might be the phase sensor you can get wrong with the knock sensor
Old Jan 25, 2009 | 01:42 PM
SWIFTY's Avatar
SWIFTY
dont think i have, the only other sensor plug that is anywhere near is my dizzy cap one, but that is black so i no its not that one
Old Jan 25, 2009 | 01:52 PM
mechanic28's Avatar
mechanic28
cool well the crank sensor needs to be around .8mm from the lugs
Old Jan 25, 2009 | 01:57 PM
SWIFTY's Avatar
SWIFTY
ill go have a look but im sure it right.
is there a way of testing it with a multi meter
Old Jan 25, 2009 | 02:48 PM
SWIFTY's Avatar
SWIFTY
the gap is right
i put a plug in the lead to watch if there is any spark.
when i turn the ignition on and of there is a spark
but no spark when you turn it over
spelling
Old Jan 25, 2009 | 08:11 PM
Paul_RS's Avatar
Paul_RS
Is your fuel pump working when you turn the engine over?
Old Jan 26, 2009 | 04:08 PM
SWIFTY's Avatar
SWIFTY
when i put the ignition on i can here it kick in.
but i noteiced somthing if my dizzy cap isnt pluged in it dont kick in till i plug it back in, is that normal.
also spoke to a mate and he told me it shouldnt be sparkin when i turn my ignition on and off.
speling
Old Jan 27, 2009 | 06:17 AM
The fact that you can here your pump kick in tells you the cps is ok.
As for unplugging the dizzy I would have thought that normal.
Old Jan 31, 2009 | 07:04 PM
SWIFTY's Avatar
SWIFTY
still no spark
been tryin to fix it for ages no with no luck anyone got any ideas why i have no spark
problem still the same. when i turn the ignition lights on and off i get a spark but when i crank it over nothing.
any help please
spelling
Old Jan 31, 2009 | 07:24 PM
MannheimAlex's Avatar
MannheimAlex
maybe stupid question, but have you checked the timing is right? dont know if its wrong it just sparks at a wrong point or it doesnt fire at all...
Old Jan 31, 2009 | 07:27 PM
SWIFTY's Avatar
SWIFTY
yes mate checked it a few times
i was told if it wass rong it still sparks but not at the right time.
i have checked it from the coil wire aswell and its the same there as the plugs
Old Feb 1, 2009 | 04:11 AM
The ignition timing is fixed mechanically by the CPS alignment with the crank pulley, so if valve timing is correct so is igntion timing, though it is possible to get cross firing in the dizzy cap, but it's not this otherwise you'd have a spark.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
