Mondeo st200 door locking problem!!
Old Jan 12, 2009 | 08:41 PM
ghigo's Avatar
ghigo
Default Mondeo st200 door locking problem!!
As above realy,
I have a mondeo st200 and went to lock it today and all the doors locked apart from the drivers door which then causes all the other doors to open up again. it has a clifford concept 600 alarm btw. i can still lock the doors manually then arm the alarm its just a pain.
was think a door module or something
any help appreiated
Old Jan 12, 2009 | 09:53 PM
Marshin's Avatar
Marshin
the exact same happend on my st200 mate only it was the passenger rear door, it turned out to be a broken central locking wire in the door that was causing the problem!!!
hope you get it sorted m8
Old Jan 12, 2009 | 10:05 PM
B19 JUB's Avatar
B19 JUB
sounds to me like the drivers door latch is at fault.hope ya get it fixed
Old Jan 12, 2009 | 10:30 PM
xr4x4rs's Avatar
xr4x4rs
count yourself lucky
all my doors decied to deadlock bar the fronts and all central locking went down, i had to change every single motor to get it working again, and now my back door has packed up again
Old Jan 12, 2009 | 10:39 PM
COLEYST200's Avatar
COLEYST200
right its the morm on mondeo,s you will have to stirp the door down as the motor that dose the locking in that door is shot you will need to get one from a tat yard and it has to be out of a mk2 mk1 are not the same in the 6 years i had my st200 i did n/s/f o/s/f r/o/s
Old Jan 13, 2009 | 03:36 PM
ghigo's Avatar
ghigo
cheers for the input guys i shall strip it down and have a look this weekend,
Old Jan 13, 2009 | 03:52 PM
Ridgey's Avatar
Ridgey
I've had the same issue and replaced drivers door mechanism in my St24 about 12 mths ago.
Something odd is atarting to happen again though , all doors locking as you are driving along sometimes.
Old Jan 13, 2009 | 08:28 PM
northernmonkey's Avatar
northernmonkey
I didn't do it!
Mine does that all the time, not at any speed or anything just totally ramdonly!
I'd love to find out what it is, MK3 mondeo though, 2.0
JoeyBoyden
Jan 4, 2024 02:36 PM
PaulinhoT
Oct 28, 2015 06:06 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
tankybaby66
Aug 9, 2015 07:13 AM
blakey100
Aug 4, 2015 08:17 PM
