help with S2 loom in my orion!!!!
Old Feb 19, 2004 | 02:34 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
Default help with S2 loom in my orion!!!!
right,i have these bits left,can any one help me with where they go,please!!
help please!!
Old Feb 19, 2004 | 05:51 PM
PJay's Avatar
PJay
Tell me the wire colour and then we'll see
Old Feb 19, 2004 | 08:18 PM
orion_crazy_carl
orion=mini saff
top pic,i cant really remember,i'll have a betta look,2nd pic 1 is purple 1 is purple and green and 1 is purple and blue,i think there fan wires of some sort
Old Feb 19, 2004 | 08:37 PM
o n i o n's Avatar
o n i o n
The top pic looks like connectors from the fuel trip computer (if it had one fitted).
The white/clear connector would be the speedo drive and the black one would be the fuel flow sensor.??????
The second picture is a vacuum/boost hose which should go to or from your amal valve.
The amal valve if you look closely will have a letter by each of the three pipes comming off it. W.R.C
1, W is the pipe from the wastegate actuator.
2, R is the return ( to the bottom of the fuel metering head).
3, C is the pipe to the compressor housing on the turbo.
The third picture I am not sure about, you could be right with the fan idea though.
HTH
Old Feb 20, 2004 | 04:40 PM
orion_crazy_carl
orion=mini saff
cheers mate,the computer wires are already hooked up,as for the pipe,i have a ajustible boost thing inside,whitch goed between the turbo and sum where,does tht mean i can block tht 1 off??
i gott the colours if it helps:
black conector is:black/yellow ,brown ,brown/green
white one :white/brown ,brown ,black/yellow(think)
my mate saiud they might be to the ABS whtich it dont use
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
