Gearbox question?
Old Jan 5, 2009 | 11:38 AM
mint_s2's Avatar
mint_s2
Default Gearbox question?
My gearbox is quite notchy especially into 2nd gear and when it is cold. It is also quite noisy especially with the clutch down while moving. It has only done 1000 miles since new from ford. It currently has the oil recommended by ford in it and I was wondering if an uprated oil would make any difference and if so which one is recommended?
Thanks
Old Jan 5, 2009 | 12:47 PM
ECOS95's Avatar
ECOS95
Not had a problem with mine & selecting 2nd gear when cold, did you get any warranty with it ?? With the correct ford oil in it should work fine from cold in any gear.
The noisy when you dip the clutch is probably the thrust bearing on the clutch.
The ford oil should be ok on a standard gearbox but some recommend 75w90 fully synth gear oil for all transmission parts. I'm going to try this in mine this year as the car & box is 14yrs old now.
Old Jan 6, 2009 | 04:51 PM
mint_s2's Avatar
mint_s2
Thanks for the reply. Unfortunately I bought it a few years ago so I doubt the warranty is still valid. The noise is definitely from the gearbox and is louder when I let off the accelerator. Ill try changing the oil - does it matter what brand oil I get aslong as it is fully synthetic 75w90 and I should put it in the gearbox and transfer box?
Old Jan 6, 2009 | 05:28 PM
ECOS95's Avatar
ECOS95
I went with Silkolene oil, they say it can go in Diffs, Gearbox & Transfer box. I've not done mine yet so can't say 100% how it works on a standard box, been told it should be ok.
Might be worth PM marco polo off here as he sells the uprated boxes & ask him what he recommends.
Old Jan 6, 2009 | 05:49 PM
ECOS95's Avatar
ECOS95
This is the stuff I bought.
http://www.opieoils.co.uk/p-850-silk...-gear-oil.aspx
Old Jan 7, 2009 | 08:11 AM
GUZZLER's Avatar
GUZZLER
Matt, the 4x4 boxes are a bit noisy, especially on overrun, normally the chain makes a lot of the noise.
Old Jan 7, 2009 | 03:55 PM
mint_s2's Avatar
mint_s2
Originally Posted by ECOS95
Thanks mate ill get some and see if it makes any difference.
Old Jan 7, 2009 | 07:01 PM
El Grand Tomismola's Avatar
El Grand Tomismola
They make EVEN more noise when they go pop
Old Jan 7, 2009 | 08:41 PM
marco polo's Avatar
marco polo
personally i dont think the oil will make any differance
if it's noisey that could well be the first motion shaft bearing for a start
and if it's notchy thats could well be a a dodgy selector fork or sncro ring fooked or on the way out
i bet the box will need looking at
most ford garges only do reconditon units
marco
Old Jan 26, 2009 | 09:55 PM
Pib's Avatar
Pib
marco
Marco
I've got a similar problem at the moment with the box in my Escort and have also had first motion shaft bearing mentioned to me.
What kinda ball park cost would I be looking at for a replacement bearing, removal and splitting the box and refitting, based on current going rate of a mechanic?
Old Feb 9, 2009 | 07:50 PM
cossiedrift's Avatar
cossiedrift
I have a decent box for sale if anyones intersted and you can drive the car to check it for yourself before i remove it.
Old Feb 15, 2009 | 09:37 AM
Dave Henshall's Avatar
Dave Henshall
the oil in the link above is spot on for the front and rear diff - but for the box itself - you need the specififc ford stuff that makes it super smooth - castrol equivelint it called FMT - you only need 1.3 litres. then some dextron 3 ( 0.5 litre) for the transfer box.
they are rattly old boxes at the best of times though - when hot they make a right old racket.
Old Feb 15, 2009 | 10:43 AM
JonathanJ's Avatar
JonathanJ
The MT 75 box is still used in the Transit and the front layshaft bearing falls apart for fun in those , try driving in 4 th gear and see if it is quieter , and then in third and see if it is at its worst , as in 4th it is at its least loaded state and in 3rd its most loaded .
Also agree with marco as if it was oil it would be notchy in all gears not just second , would suspect a selector or a synchro hub / baulk ring issue to be the cause of this .
Hope this helps
Old Feb 18, 2009 | 01:04 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the specific oil for the mt75 makes a world of difference, but you need to start looking back a few years to find out what it is, rather than going to ford and asking for something which they have decided is better for you
if it's the input shaft bearing then these can be changed for not a lot of money, but it's the cost of getting the box out in the first place, and for that you might as well get the whole thing reconned
Old Feb 19, 2009 | 10:19 AM
georgie1's Avatar
georgie1
what box is it standard or uprated
Old Mar 8, 2012 | 06:05 AM
Cossy Mike's Avatar
Cossy Mike
How much roughly?
Mine needs 2 seals and the main shaft bearing done and it's out of the car ready to go.
I don't want to be put on the spot when I take it somewhere :L
I really have no idea.....would it be more near £10/100/400?
thanks!!
Old Mar 8, 2012 | 06:39 AM
dojj's Avatar
dojj
My mate used to do it for me and it was £100 box in and out and fluids plus whatever it was in bits
Never paid more than £300 all in but I was an 8 time repeat customer so he was pretty quick at getting the box out
For someone who's never done it before it may look a bit daunting as there is a lot to pull apart, certainly not something I'd want to do on my drive
Old Mar 8, 2012 | 06:41 AM
dojj's Avatar
dojj
Didn't see you had th box out so it shouldn't be more than £100 as the bearing is £50 and it's only a few bolts
You might be able to do it yourself
Old Mar 8, 2012 | 08:03 PM
Cossy Mike's Avatar
Cossy Mike
thanks!!
I was not expecting any change from £300!!
Old Mar 8, 2012 | 08:11 PM
dojj's Avatar
dojj
if that's the only thing that needs changing then you may be lucky and someone will be able to do it for you
i've heard of folk doing the bellhousing swap to make a 2wd v6 box for as little as £40 so it's not expensive
get a few quotes first as normal
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
