how 2 fit oil/air cooled turbo??
i bought a turbo off ebay 4 a escort rs, just tried 2 fit it, an its water cooled instead of oil cooled, is there any chance i can still fit it sum how? cheers
Whatever you do dont join the water to the oil pipes!!!!
What you have is a S2 turbo which has water cooling (but isnt needed) and you must be running a S1 setup in your car which doesnt have water cooling.
So just hook up the oil pipes as they were on your old turbo, and leave the water pipes disconnected or even remove them from the turbo.
http://cgi.ebay.co.uk/Fiesta-Escort-...1%7C240%3A1318
theese are the pictures on the ebay link above 2 the turbo i bought,
cheers 4 all ur replies an advice....so oil feeds only and ignore the water
Yes make sure you do this! Most important to let it idle for a minute or 2 before shutting off the engine or you'll get extreme heatsoak in your turbo and cook the oil in there!
marky_g
Aug 15, 2015 10:43 AM
