running problem
Old Dec 29, 2008 | 02:17 PM
Korda's Avatar
Korda
iv got my car out the garage and its playing up again iv put a new fuel pump in, new relay,
iv tryed 3 meter units. its been running for 1 day, then wont run theres fuel upto the the meter unit but none to the injectors but i could go out to it i it would run for a bit then die ??????
Old Dec 31, 2008 | 08:54 AM
Korda's Avatar
Korda
bump
Old Dec 31, 2008 | 09:22 AM
Red_bull's Avatar
Red_bull
first thing that comes in mind is remove the airfilter en see if the plate of the Kjetronic system moves down. If it doesn't you won't get fuel on your injectors. And if that is the problem you have an airleak
Old Dec 31, 2008 | 09:50 AM
Korda's Avatar
Korda
all moves mate seems a bit odd iv got fuel upto the head but non to the injectors. then it was running fo an hr then stopped
Old Jan 3, 2009 | 06:18 AM
Korda's Avatar
Korda
need help anyone ????
Old Jan 3, 2009 | 08:45 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
my mate had this prob on a s1,gave up and sold it.best to get it 2 someone like jamsport or possibly someone more local to u mate.is the fuel line that goes to cold start injector working.is fuel flowing thru it?
Old Jan 3, 2009 | 11:22 AM
Korda's Avatar
Korda
cold starts working its been in the garage twice they get it running then it will do it the next day or so
Old Jan 4, 2009 | 04:47 PM
rickbartlett
G911 TTA
is ur heated seats fuse in the fuse box?(that helps the fuel ecu)
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
