Engine miss only when engine is warm !
Old Nov 21, 2004 | 08:44 AM
lee peneycad's Avatar
lee peneycad
Default Engine miss only when engine is warm !
Hello this problem is doing my head in, i have had two sets of plugs in the car, changed the rotor arm and dizzy cap. I dont think it could be leads cos its only doing when the engine is hot.
The miss is right through the rev range it does not keep boost or anything any ideas ?
Old Nov 21, 2004 | 10:02 AM
wimwerf's Avatar
wimwerf
what car do you have?
sierra, 2wd saff of 4wd saff
Old Nov 21, 2004 | 10:09 AM
lee peneycad
hello its a 2wd saff g plate. I was thinkin it could be map sensor or that iginition amplier thing. I aint got a clue really as this is my first cossie !
Old Nov 21, 2004 | 11:27 AM
wimwerf's Avatar
wimwerf
what stage tuning you got?
you have two sets of plugs? maybe you check the gaps of the plugs.
Old Nov 21, 2004 | 11:35 AM
lee peneycad
hello the car is totally standard i have tried the gap of .8 and.6 and still no joy. I just cant understand how it only does it when the car is warm and not got cold
Old Nov 21, 2004 | 11:36 AM
RS500/364's Avatar
RS500/364
always check the phase sensor !!!!!!!!
Old Nov 21, 2004 | 11:42 AM
lee peneycad
which one is the phase sensor and where is it ?
Old Nov 21, 2004 | 03:39 PM
wimwerf's Avatar
wimwerf
your phase sensor is under the rotorarm/dizzycab.
Old Nov 21, 2004 | 03:52 PM
lee peneycad
is that the tdc sensor ! what is the gapping for this ?
Old Nov 21, 2004 | 06:29 PM
wimwerf's Avatar
wimwerf
the TDC is the sensor next to the crank pulley. correct if im wrong
Old Nov 21, 2004 | 06:34 PM
lee peneycad
yes that is the tdc sensor so is this phase sensor expensive and is there any way i can check it ?
Old Nov 21, 2004 | 09:14 PM
wimwerf's Avatar
wimwerf
the only sensor which is expensive is the lambda i guess
Old Nov 23, 2004 | 08:05 AM
foreigneRS's Avatar
foreigneRS
Testing the future
get yourself gold membership for 20 quid mate, and then go to the technical essay archive where you will find a manual for the YB engine that tells you how to check and gap all sensors
JoeyBoyden
Jan 4, 2024 02:36 PM
3drRich
Sep 13, 2015 07:32 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
