cosworth electric? problem
Old Dec 18, 2008 | 09:38 PM
Thanasis's Avatar
Thanasis
Default cosworth electric? problem
Hello everybody,the last week I washed my cossie engine with a lot water and detergent of car,so after this the engine is not work good,behind of exhaust smells petrol and removes black smoke,also at idle it tangles,then I blew all connectors with air but nothing,so i replaced the sparks plugs,also the ECT Coolant Sensor - Blue with new and the ACT Air Charge Sensor - Brown too,but the problem still there,i think somebody electric part must be burned,any idea? thanks a lot
Thanasis
*sorry for my bad English.
Old Dec 19, 2008 | 08:19 AM
Have you checked inside your dizzy cap. Make sure its not full of condensation.
Old Dec 19, 2008 | 11:24 AM
mechanic28's Avatar
mechanic28
as above
Old Dec 19, 2008 | 12:14 PM
Thanasis's Avatar
Thanasis
it's clear inside the DISTRIBUTOR...
Old Dec 19, 2008 | 12:21 PM
mechanic28's Avatar
mechanic28
have u checked around the phase sensor etc
Old Dec 19, 2008 | 12:29 PM
Thanasis's Avatar
Thanasis
yes mate,i do,somewhere there is humidity but where? i think..
Old Dec 19, 2008 | 12:30 PM
MannheimAlex's Avatar
MannheimAlex
Had similar probs on mine with washing my engine. In the end i had a faulty map sansor and a f**ked up wireingloom. Because a cossi is getting old, the the loom can suck some water an causes a short in the wires and kill some sensors.
Old Dec 19, 2008 | 01:09 PM
olek's Avatar
olek
map-sensor would be my guess.
try to remove it from the car and lay it on someplace warm overnight. se if that will work, if not, replace it.
map-sensor + engine-wash = be careful!
Old Dec 19, 2008 | 05:58 PM
I would never wash my cossie engine like you have done.I bet you dont do it in a hurry again too.
Old Dec 19, 2008 | 06:54 PM
Thanasis's Avatar
Thanasis
thanks for all replies,
regards
Old Dec 19, 2008 | 08:02 PM
Have you got it running yet.
Old Dec 19, 2008 | 08:24 PM
Thanasis's Avatar
Thanasis
not yet mate,today i removed from my car the map and i will fit it the same again tomorrow
Old Dec 20, 2008 | 01:59 PM
Thanasis's Avatar
Thanasis
finally it was the map,i'm ok now thanks to everybody.
CLIVE
Oct 2, 2015 12:58 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
dlwarrior
Aug 5, 2015 10:19 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
