Saph Brakes
Old Dec 17, 2008 | 09:17 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Default Saph Brakes
Right my pedal sits half way down and is rock hard. They work but you have to push hard. When you turn the ignition on you can hear the pump. Whats the correct procedure for bleeding the brakes aswell and ive had the pedal box out so not sure if i put it back right, the rod that goes through the brake pedal, does the clip go infront or behind the pedal???
Old Dec 18, 2008 | 07:38 AM
I'll stop over today and have a look for you, see you later.
Old Dec 18, 2008 | 08:03 AM
bigjim172000
Noice one
In fact hang on, the cars at home At least i could look at yours and see if i did something wrong when i put it back
Old Dec 18, 2008 | 06:49 PM
biggiejody's Avatar
biggiejody
the clip goes in front of the pedal (closest to u and not behind) and when the rod comes through, this should have a white round hard plastic spacer, approx 1/4 inch.
to bleed the brakes up i think u need the ignition on, and start furthest away from the servo (nsr, osr, nsf,osf)
hope this helps
Old Dec 18, 2008 | 07:25 PM
bigjim172000
hope this helps
Dont think i have this hard round plastic spacer,
Thats the workshop manual page, at the mo, my pedal is going straight onto the collar which holds the spring.
Old Dec 19, 2008 | 03:11 PM
As said, and as said also yesterday, it needs the hard plastic bit, available seperately from ford for pence, it pivots on this, so needs to be there.
Old Dec 19, 2008 | 06:40 PM
dojj's Avatar
dojj
Resident Wrestling Legend
ignition on for the rear curciut, just press the pedal and the pump will pump the fluid to the rear
the fronts are done as normal, no ignition
cheating and bleeding with an e-z-bleed kit sometimes causes the most horendous problems as some will atest to, so do it the way it's supposed to be done to avoid these mishaps
Old Oct 6, 2010 | 07:29 PM
focus 4x4's Avatar
focus 4x4
Originally Posted by bigjim172000
dont think i have this hard round plastic spacer,
thats the workshop manual page, at the mo, my pedal is going straight onto the collar which holds the spring.
anyone got a picture of the small plastic bit ? Im missing this bit on my car!!!!
Old Oct 6, 2010 | 07:35 PM
focus 4x4's Avatar
focus 4x4
Anyone got one of these little plastic bits kicking about?
Old Oct 7, 2010 | 04:26 PM
They fit masses of fords so will still be able to get one from some ford car, if not cossie, they use a different colour on some assume it must be the thickness, it's just there to act as a pivot point where the rod from the servo/pump passes through the pedal, it sits in the cup shape on the rear of the brake pedal that has the hole for the rod through the centre, maybe scrappies or even make one out of aluminum or delrin easy enough.
Old Oct 7, 2010 | 04:42 PM
focus 4x4's Avatar
focus 4x4
Cheers Tabs , i ordered one from fords this afternoon (76p) along with the clip that holds the pedal in place on the servo/pump rod.
thanks again!
Old Oct 7, 2010 | 07:17 PM
No probs matey, anything for an essex dude, I used to live there on Imphal Close!!
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
