Engine advise needed
Old Dec 9, 2008 | 07:43 PM
tobyjug_1988's Avatar
tobyjug_1988
Default Engine advise needed
after selling my s2 i got rid of most of the spares i had knocking about aswell but have still got an engine block and crank in my garage (its the block with the hole about an inch round on the flywheel end, which i believe is a 90 spec block?!) and i was thinking of building an engine as a project in the new year.
the block has no scoring in the bores but was the original block in my s2 which had done 150k miles without a rebuild and the crank appears to be in good condition aswell.
ive been thinking of a spec for the engine whilst bored at work and in my free time and was wondering on what sort of spec for a genuine 200+bhp motor.
i was thinking along the lines of:
forged pistons and rods
slight over bore maybe 0.5
regrind the crank
new shells and bearings etc
efi conversion (believe the hole in the block is for a flywheel pickup)
ported and polished head
uprated cam
stage 3 t3 or t34
possibly cossie management
just asking if anybody has the same basic set up and what companies they would recomend. also would be nice to know what sort of prices
cheers in advance
Old Dec 9, 2008 | 07:46 PM
RS 5tu's Avatar
RS 5tu
if you do that you will see over 200bhp
usually a cam,chip,fmic,K&N and a decent exhaust should do you 200 depending on you engine
Old Dec 9, 2008 | 07:54 PM
tobyjug_1988
cheers for the reply mate, kinda wanted to over engineer it any way for relaibilty and a scope for further tuning (can always de-tune it if it got much lol) just think it would be a good little project that won't take up as much room as my last one lol. would like to eventually put it in a series one or series one replica
Old Dec 10, 2008 | 07:37 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
good engine spec imho should see reliable power over 200 bhp
Old Dec 10, 2008 | 11:58 AM
B16CVH's Avatar
B16CVH
regrind the crank
uprated cam
stage 3 t3 or t34
cheers in advance
Go for:
+0.5mm Overbore with torque plate & Ultra-fine finish
Forged Pistons (Cossie)
Farndon Steel Rods
If the crank is ok, just have it checked/micropolished
New Oil Pump
ACL HD B/E`s & Mains
Balance the lot
= Reliable powerhouse!
Old Dec 10, 2008 | 04:30 PM
tobyjug_1988
sounds all good, anyidea on how much this would all cost?
Old Dec 10, 2008 | 08:56 PM
B16CVH's Avatar
B16CVH
Forged Pistons (Cossie) £450ish
Farndon Steel Rods £700
New Oil Pump (£50+)
ACL HD B/E`s & Mains (£100)
Balance the lot
All your maching inc balancing should be around the £250 mark. You can get cheaper steel rods for around the £350 mark also
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
dal3door
Aug 13, 2015 06:55 AM
Zoggon
Aug 10, 2015 10:39 AM
col93saphcos
Aug 7, 2015 03:21 PM
