oil pump 2WD 4WD
Old Dec 5, 2008 | 09:37 AM
florent78's Avatar
florent78
Default oil pump 2WD 4WD
can someone explain me the difference between :
- 2WD standard Oil Pump
- 2WD High Pressure Oil Pump
- 4WD standard Oil Pump
- 4WD High Pressure Oil Pump
I assume the difference between the standard and the high pressure is a harder spring but
- what is the gain to expect with a high pressure ?
- can you put a 4WD oil pump on a 2WD block
thanks
Old Dec 5, 2008 | 09:31 PM
florent78's Avatar
florent78
any idea ???
Old Dec 6, 2008 | 08:54 AM
im sure the 2wd pumps are different to 4x4.i would advise a high pressure pump over a standard pump.
Old Dec 6, 2008 | 03:57 PM
col cos1's Avatar
col cos1
4x4 pump is diffrent but you can fit it if you bend the pick up pipe
there is nothing wrong with a proper standard pump,not a ggr one though
col cos1's Avatar
col cos1
Old Dec 7, 2008 | 10:59 PM
florent78's Avatar
florent78
what are the difference ???
what is a benefit ? standard versus high pressure ??
thanks
Old Dec 8, 2008 | 05:55 PM
Paul_RS's Avatar
Paul_RS
Think the 2wd one i loosly pinto based? The 4x4 one was carried over from the RS500 pump and is supposed to be a lot better?
JK12
33
Apr 26, 2021 12:09 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
Adam-M
Aug 26, 2015 05:53 PM
