problem starting
Old Nov 18, 2004 | 05:09 PM
james_birch's Avatar
james_birch
Default problem starting
When i start me car...weather it morning or after a run it turns over loads before starting? ideas? maybe plugs or sumit?
Old Nov 18, 2004 | 06:36 PM
sufsRS's Avatar
sufsRS
whens last time it were serviced? good service might do trick, did on mine anyway now starts evry morning 1st time
Old Nov 18, 2004 | 06:41 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine did that last year,new set of injectors and it starts first time.
Old Nov 18, 2004 | 08:34 PM
james_birch
ermmmm...aint been serviced for about 6 months! but just had an oil change! will get some new plugs! if that dont sort it ill look at the injectors and all that bollox!
Old Nov 19, 2004 | 04:41 PM
Moonie's Avatar
Moonie
Try disconnecting the cold start injector
Old Nov 20, 2004 | 11:30 AM
adamS2RST's Avatar
adamS2RST
James, as above i'd say, change the plugs, give it a new fuel filter whilst you are there ! see how you get on then
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
