How to make a low compression engine
Old Dec 3, 2008 | 08:56 AM
turbo_boost's Avatar
turbo_boost
Default How to make a low compression engine
Orite fellas
doing a bit of reading and i wanted to know i wana run a turbo on my 325i sport m tech 2 know the compression is high at 8.5.1 or 9 something not sure the exact pressue i wana drop the compression and strap a turbo on to it running about 12psi
Will the pistons have to be chnaged im new to moded engines but am going to do the work myself
Old Dec 3, 2008 | 08:58 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If your compression is at that sort of level, its about the same as most modern turbo engines anyway.
Id have thought 12psi on 98 ron would be a breeze.
Ways to lower CR though:
Low comp pistons
Thicker head gasket
Open the combustion chamber up a bit more (often possible on 2v engines)
Old Dec 3, 2008 | 09:11 AM
R4N SS's Avatar
R4N SS
what is the comp ratio on the 2.5 - i thought it was higher than that
Old Dec 3, 2008 | 09:15 AM
turbo_boost
i think its 9 something so using a thick layer head gasket would reduce the compression i dont want to spend mega money on the engine just want to get the car from the standard 160 bhp to about 250bhp
Old Dec 3, 2008 | 09:31 AM
R4N SS's Avatar
R4N SS
I am interested in this also - anyone know what comp ratio a 2.7 engine is?
Old Dec 3, 2008 | 09:41 AM
turbo_boost
I was thinking of boring out my 325 engine to 327 then turbo the mofo, however i may stick to a 325 unless i can do it cheap engines are peanuts about 250 for engine and box and a whole turbo kit from the states is 800 unless i can get it done a bit cheaper hear might get the bolt on kit
Old Dec 3, 2008 | 11:01 AM
Chip's Avatar
Chip
Try it at standard CR first, see what sort of ignition values you end up with at peak torque on 98 RON and it should be obvious if you need to change CR and by how much.
Old Dec 3, 2008 | 11:15 AM
Garage19's Avatar
Garage19
If this is a 325 m20 lump you will be fine with a low boost setup.
After that there is a thick HG and easy stud/nut kit conversion that should see you upto 350 bhp ish.
Old Dec 3, 2008 | 11:25 AM
R4N SS's Avatar
R4N SS
doug - got any links?
Old Dec 3, 2008 | 11:53 AM
turbo_boost
Garage 19: what stud nut kit this would be ideal if the headgasket and nut kit would let me boost 350bhp as long i dont have change the pistons any time soon
Also are the ebay bolt on kits any good
Old Dec 3, 2008 | 12:01 PM
badnews's Avatar
badnews
the e30zone is a good place to start i havent got a link but plenty of info there mate
Old Dec 3, 2008 | 12:02 PM
turbo_boost
will have a butchers over there
Old Dec 3, 2008 | 12:03 PM
R4N SS's Avatar
R4N SS
e30zone is full of twats
Old Dec 3, 2008 | 12:05 PM
badnews's Avatar
badnews
if i remember right the kits for the USA are for left hookers and foul the stearing i not sure but i think the turbo diesal manifold can be flipped to forward mount a turbo as i have said it's all there on the e30zone
Old Dec 3, 2008 | 12:06 PM
badnews's Avatar
badnews
spadge was there for a while he was the man
Old Dec 3, 2008 | 12:10 PM
R4N SS's Avatar
R4N SS
why not use a std manifold and turn it upside down?
it works as have seen it done
Old Dec 3, 2008 | 12:20 PM
turbo_boost
If i flip the orginal then what do i do with the exhuast i need to do some more reading however anyone local to london willing to give me a hand
Old Dec 3, 2008 | 12:29 PM
SapphyMike's Avatar
SapphyMike
The 325 lump is 9.7:1 c/r isnt it?
Old Dec 3, 2008 | 12:36 PM
turbo_boost
Thats the one if its only head gasket to lower the compression il do it to run a stable 300bhp lets say the car will be interesting and i dotn liek e30zone their bit werid
Old Dec 3, 2008 | 12:45 PM
badnews's Avatar
badnews
zoner's may be strange but there is all the info you need on there mate, i bought lots of stuff for my old 325 off there and never had a problem. you seem to have judged it quick lol less the an hour
Old Dec 3, 2008 | 12:48 PM
SapphyMike's Avatar
SapphyMike
I fancy a turbo'd E36 335 or something..
But i'll make do with not spending money on tuning cars lol
Old Dec 3, 2008 | 01:52 PM
R4N SS's Avatar
R4N SS
my e30 aint moved in almost 2 years -
dunno whether to break it/sell it whole or put it on the road
Old Dec 3, 2008 | 03:34 PM
ECU Monitor Enthusiast
Just for info....
If you only run about 6 to 8 psi, you can get a 30 to 40% power increase without touching the CR on pump fuel and probably wont need an intercooler if the turbo is specced right !
This is called low pressure charging..
Old Dec 3, 2008 | 03:47 PM
R4N SS's Avatar
R4N SS
Simon what turbo would you recommend for this?
Also would you require an additional injector for fueling, Im assuming a cossie IC would be sufficient for low boost.
Old Dec 3, 2008 | 03:54 PM
I cant recomend a turbo as I am not clued up with turbo specs.
Unfortunately I am not familiar with this engine but an extra injector will work fine but some vehicles with AFM's can add extra fuel nicely to a point but there is only one way to find out....try it !!!
Old Dec 3, 2008 | 04:01 PM
R4N SS's Avatar
R4N SS
cheers - I have a mate who is really into his BM's and breaks quite afew E30s. he used to have a turbo'd E30 335i too, and still has several supercharged e30s.
german ebay (ebay.de) is a good bet for any parts you may need for turboing an e30. Possibly ebay.com for the US parts
Old Dec 3, 2008 | 04:19 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
There's no real reason NOT to use an intercooler though, as it's beneficial at all boost levels.
yatta
Sep 1, 2015 11:28 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
155lee
Aug 14, 2015 11:21 AM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
