focus rev's high
Old Dec 1, 2008 | 06:01 PM
MK5RS2K's Avatar
MK5RS2K
on you come!
Unhappy focus rev's high
hey,my 1.6 1998 focus developed a fault during the weekend,as soon as u turn the engine on it revs to bout 3500rpm and stays there,if you try and rev it the revs go up then slowly return to 3500,the manifold is also glowing red hot after bout 2 minutes,could it be my idle control valve as the car runs ok wen your doing anything over 40mph above 3000rpm.
cheeRS Ronnie
Old Dec 1, 2008 | 06:34 PM
Allyc85's Avatar
Allyc85
Yea id say so. Either replace it or give it a clean out with some carb cleaner.
Old Dec 1, 2008 | 06:58 PM
MK5RS2K's Avatar
MK5RS2K
on you come!
cheeRS mate il give it a try
Old Dec 1, 2008 | 07:23 PM
RichieST's Avatar
RichieST
Sounds to me like its sticking open. You may also have an air leak after the air flow meter. Disconnect the air flow meter and start the engine, see if it is still the same. You will need to disconnect the battery for a few mins afterwards to reset the fault code in the ecu though
Old Dec 2, 2008 | 06:16 PM
MK5RS2K's Avatar
MK5RS2K
on you come!
cheers rich,il give that a try
TPM961
Jan 15, 2018 10:50 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
JamboRS
28
Sep 14, 2015 09:02 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
