Engine Problem
Old Dec 1, 2008 | 05:06 PM
ace1st2000's Avatar
ace1st2000
Default Engine Problem
hi guys i got 2 rs turbo and the head gasket has gone on one but the other engine runs fine no problems and i took it out and changed it in to my other one but there seems to be a miss fire and running really rich but the engine was fine when i took it out anyone have any ideas of wot it might be thanks
Old Dec 1, 2008 | 05:08 PM
adam.d's Avatar
adam.d
Wait a min, you swapped engines over because the head gasket went?
Think the only way to get these cars to run propper is to have them setup on a rolling road.
Old Dec 1, 2008 | 05:14 PM
ace1st2000's Avatar
ace1st2000
Default engine
well the other engine was a bit fu**** so i put me other one in but its miss fireing now and running rich but it was fine in the other car inless i aint put somethink back on propley a plug or somethink or somethink in the wrong place
Old Dec 1, 2008 | 05:17 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
pat,u got some turbo bits for sale now then??check all ya plugs in the right pleaces?
Old Dec 1, 2008 | 06:03 PM
adam.d's Avatar
adam.d
Iirc, all the plugs on the back of the inlet manifold are easly put on in the wrong place as the sensor plugs are all the same, I'd check these first. Other than that make sure your leads are all on in the right order! you aint knocked the dizzy when removing/refitting have ya?
Old Dec 1, 2008 | 06:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If you didnt swap the metering head over and put the dizzy in exactly the same place, the timing will be out and your fuelling will be wrong.
Get it setup is the best option to be 100% sure its all right though!
Old Dec 1, 2008 | 07:21 PM
ace1st2000's Avatar
ace1st2000
Default engine
i will check all the plugs on the engine thanks and yes carl i am brakeing a white turbo wot u arfter
Old Dec 1, 2008 | 07:55 PM
marky_g's Avatar
marky_g
Fleet Manager
it'll need a set up, that's a general fix all for shit running
Old Dec 2, 2008 | 09:22 AM
RSTurboSI's Avatar
RSTurboSI
as above will need a setup Tbh.
The dissy caps need to be set up with a white timming gun and then get it setup on rollers for your fuel...
Old Dec 2, 2008 | 03:47 PM
ace1st2000's Avatar
ace1st2000
Default engine
hi guys there was a yellow plug on the back of the engine the i did not put on i put it on nd it run ok just think the timeing needs doing now but i took it up the road and the plug come off as its broke can u buy them or wud it be a scrap yard job
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
