Running lean problem
I have a 1991 Sierra RS Cosworth 4x4 and it has the following upgrades:-
- 3 bar map sensor
- Stage 2 sue collins chip
- Light Green Injectors
- -31 Auctuator
- Cone Air Filter
So your fuel pressure with half a bar or so of vacuum is 2.8 bar, and with 1.1 bar of boost is 3.5 bar?
If so, I would say that you have a problem with your pump or pump wiring, or possibly even the diaphram in your regulator, as if its 2.8 on idle, it should be 4.5 or so when running 16psi of boost!
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
