HELP needed about ET wheel offset.
Old Nov 28, 2008 | 05:40 PM
craigb78's Avatar
craigb78
Default HELP needed about ET wheel offset.
right im new to here but was jsut wondering if anyone would be able to help me at all.
right i have a Racing Puma and wheel offset for these standard is ET25 i think. and i am thinking about gettin a set of Comp MO 6spokes but the ones i can find for sale are either ET35 or ET18. would these fit. and is the ET number the amount of mm from the hub to the wheel center?
help would be very much appriciated
thanks
Old Nov 28, 2008 | 05:43 PM
Rs1's Avatar
Rs1
Maybe use the 35's and space them?
Old Nov 28, 2008 | 05:47 PM
craigb78's Avatar
craigb78
yer you know what size spacers would be needed dude?
Old Nov 28, 2008 | 05:49 PM
TwoCossieBob's Avatar
TwoCossieBob
Default Wheel Offset
hi
use this calculator to work out the difference between your original wheels and any new ones you may be considering.
http://www.1010tires.com/WheelOffsetCalculator.asp
once you have done the calculation just go out and check on your car if there is enough clearance with the new dimensions as calculated.
remember the calculator is only for the rim, if you are going to use a wider tyre then don't forget to adjust the calculated figures to suit.
hope this makes sense and helps you out.
bob
Old Nov 28, 2008 | 05:52 PM
craigb78's Avatar
craigb78
bob thanks alot dude i will try that now you are a legend
Old Nov 28, 2008 | 06:31 PM
Farmer Giles's Avatar
Farmer Giles
have a read of this site
info on standard PCD, offset and spigot sizes for alot of cars and also, at the top, a link that explains about every aspect of the wheel sizes.
enjoy
Old Nov 29, 2008 | 07:14 AM
rsjp's Avatar
rsjp
graig
if you want to try these comp mo s ive got here your more than welcome ive also got some spacers you could try
jp
Old Nov 29, 2008 | 08:48 AM
dojj's Avatar
dojj
Resident Wrestling Legend
speak to martin hadland of reyland fame, he'll be able to sort you out a set of rims with whatever offset you need, i know that the racing puma's had some weird offset, but i'm not sure if that was to fill the arches or just to clear the brakes, that's the first step to getting what you want, no use getting a set of rims that have the right offset but fail to clear the 4 pots
JoeyBoyden
Jan 4, 2024 02:36 PM
Chas
Sep 21, 2015 08:57 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
bassboy
Aug 8, 2015 10:21 AM
col93saphcos
Aug 7, 2015 03:21 PM
