saff cossie 4x4 fuses
Old Nov 27, 2008 | 07:41 AM
Default saff cossie 4x4 fuses
Hi people first of all is there a fuse that i can take out to stop my head light wipers from working. The wipers only go half way up the head lights then stop. Also i have noticed that the fuse for my fans (green 30amp) looked a bit melted. Is there any way to stop this or shall i just keep am eye on it n if it does it again just change it. I know that cossies suffer from poor fan wiring due to age.
Old Nov 27, 2008 | 08:17 AM
I would forget about the ford wiring for the fan and do a rewire immediately, if not sooner, they were crap when new in this repsect and get worse with age, simple job to do under Ł5 diy.
There is a relay(timer) that operates the headlight wipers when the lights are on and the washer operated, pull this(don't know which one as car not here),or just unplug them.
Old Nov 27, 2008 | 11:19 AM
Whats the best way to wire the fans up then.
Old Nov 27, 2008 | 05:54 PM
Just a SPST, single pole single throw relay, ie very std type common one around Ł3 or so, few lengths of wire, fuseholder near to battery, terminals to suit, then just run a live to switch, then back from switch to relay to trip relay, then output from relay to fans, beef up the earth to the fans at same time.
If you want overide switch simply tap another switched live onto relay "trigger" position.
Old Nov 27, 2008 | 09:18 PM
Sounds easy enough.I will have to get it sorted.
Old Nov 28, 2008 | 03:16 PM
It is quite easy to do, just make sure you use a 25 amp blade fuse between battery live and relay, as close to battery as possible to protect it.
Old Nov 28, 2008 | 07:44 PM
Thanks tab your the man.
Old Nov 29, 2008 | 10:42 AM
dojj's Avatar
dojj
Resident Wrestling Legend
put your hand up behind the bumper and you will find the plugs for the wipers cliped to the underneath of the panel (the one that the lowest light fixture screw goes into)
just unplug the motors, easy
the water will still come out though so then what you need to do is unplug the washer pump from the bottle, just don't pull the motor out the top as they have a habit of doing that
there are 2, i think it's the one on the rad side of the bottle you need to remove though
Old Nov 29, 2008 | 03:28 PM
i could use the other washer bottle pump to squirt water onto the intercooler to keep in cool
Old Dec 5, 2008 | 03:01 PM
dojj's Avatar
dojj
i did that in 2000 mate
but what i did was removed the bumper and fitted another washer bottle to the other side of the car, all i had to do was remove the indicator to top it up
got soem funy looks when sticking a hosepipe intot he headlight thoguh
Flatlinedan
Sep 18, 2015 12:41 PM
tib2220
Sep 14, 2015 12:33 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
