well thats buggered it!!!!!!!!
Old Nov 26, 2008 | 08:45 PM
mechanic28's Avatar
mechanic28
Default well thats buggered it!!!!!!!!
just took ages cutting my 2wd fuel pipe from thefeul rail to the metal pipe from under the car (pipe had already been cut by previous owner half way down and fitted normal pipe!)as i am switching my 2wd inlet plenum over to a 4x4 one!got the job lot plenum,fuel rail,regulator and o.e fuel pipes!but how ever the 4x4 pipes from the rail are not wide enough to fit over my metal pipes from under the car now i am stuck!the only option i can think off is cutting the o.e pipes from the fuel rail,fitted normal fuel pipe!and driving ot very slowly up to either karl or tony to get it set up and the map adjusted and get him to fit aeroquip pipes?
Old Nov 26, 2008 | 08:50 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
why cant you fit the quip lines yourself?
a roll of -6 and some fittings job done
Old Nov 26, 2008 | 08:55 PM
mechanic28's Avatar
mechanic28
what connectors to they use tho?as jubilee clips are no good !those fuel pipes where a bastard to get off!ended up taking the hack saw to them
Do you know if the o.e 2wd pipes will fit on to a 4x4 fuel rail/regulator?if i can get hold of a set?
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I need all mine doing as well.
Steve
Old Nov 26, 2008 | 08:58 PM
JTECH James
Passion for Fords!
no idea if they fit..
you can get aeroquip fittings which are based on a jubilee clip, but its a pikey way of doing it tbh....
it isnt hard to do mate, you can get fittings which fit the fuel filter, run the hose up the the rail, which will need an- fittings braized onto it.
or you can go all out like i did, and get a billet fuel rail with aeroquip fittings, and an aeroquip fitment fuel reg, then run aeroquip lines up and back, using all aeroquip lines and fittings on the fuel pump, filter etc
Old Nov 26, 2008 | 09:01 PM
mechanic28's Avatar
mechanic28
I see cheers for the input jtechsaff!ah crap!why do these simple jobs always turn out to be pants!!!!!!thought my 4x4 lines would simply click on to the metal pipes!but do they bollocks lol!!!!!!
Old Nov 26, 2008 | 09:05 PM
Ginge !'s Avatar
Ginge !
just finding my feet
im about to quip my car,,, fucking HATE being someone with "quip" but on the fuel system its gonna be needed,,,, not so sure if anyone needs quip breather hoses though
Old Nov 26, 2008 | 09:06 PM
Miller 3's Avatar
Miller 3
The pipe work is easy Doug but you will get a bit stuck @ the reg end... I have seen a fitting welded on the oe reg before and i was going to do this but ended up buying a Aeromotive fuel reg http://cgi.ebay.com/ebaymotors/ws/eB...%3AIT&viewitem=
Old Nov 26, 2008 | 09:08 PM
JTECH James
Passion for Fords!
aeroquip is ideal hose for breathers as it doesnt discolour or mis-shape like normal hose.
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by miller3
The pipe work is easy Doug but you will get a bit stuck @ the reg end... I have seen a fitting welded on the oe reg before and i was going to do this but ended up buying a Aeromotive fuel reg http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
You can do mine then Doug
Steve.
Old Nov 26, 2008 | 09:10 PM
JTECH James
Passion for Fords!
its easy stevie boy
Miller 3's Avatar
Miller 3
Not a problem Steve mate
Old Nov 26, 2008 | 09:11 PM
JTECH James
Passion for Fords!
i chose to run -8 up to the rail,
-6 return
and -10 from tank-pump
i also used the reg doug did,
Old Nov 26, 2008 | 09:13 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Get on MSN that man
Steve.
Old Nov 26, 2008 | 09:14 PM
mechanic28's Avatar
mechanic28
Ah crap i feel my wallet getting lighter then i had hoped !i should of stayed with my 2wd plenum
Old Nov 26, 2008 | 09:16 PM
JTECH James
Passion for Fords!
you can use the 2wd rail and reg on the 4x4 plenum......just have one of the mounts chopped and moved over
Old Nov 26, 2008 | 09:20 PM
mechanic28's Avatar
mechanic28
yer and you have to get abracket welded on for the regulator i seem to remember?might as well fit my 4x4 rail now i have got it
Old Nov 26, 2008 | 11:37 PM
costina's Avatar
costina
Live long and prosper!!
I still use a 2wd reg on 4x4 plenum just made a spacer and bracket
I will dig out a pic tomorrow
Paul
Old Nov 27, 2008 | 06:45 AM
BigErn's Avatar
BigErn
Mine has a 4wd rail and reg on a 2wd plenum. Fitted by previous owner.
Cragrat
Sep 2, 2015 08:25 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
CAPRIBABY
12
Nov 19, 2004 10:04 AM
Cossie Sean
13
Oct 10, 2004 11:26 PM
