vectra problems
Old Nov 26, 2008 | 07:38 PM
trebor's Avatar
trebor
Default vectra problems
got a vectra 2.0 gls the twat keeps cutting out at junctions but starts fine straight after. ive changed spark plugs.
any one got any ideas?
Old Nov 26, 2008 | 07:43 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Same problem as every other vectra in the world. Its the idle speed control valve. they get gummed up and shitty, take it of clean it, if no luck then replace, Also inside the inlet manifold there is a tiny pinhol breather type affair, this get shitted up to, Strip it and carb cleaner and a pin will sort you right
Old Nov 27, 2008 | 11:42 AM
C4llyT's Avatar
C4llyT
Ecotec, clean every breather etc you can find.
Is ICV as said most likely, not that expensive I remember I got one online somewhere cheap enough.
Old Nov 27, 2008 | 11:50 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Exactly as posted above. Its the little breather in the inlet which often gets overlooked. I had an Omega 2.0 16v and this breather was blocked solid with carbon deposits. had to run a very fine drill bit through it to clear it. Ran like a dream after that.
Old Nov 27, 2008 | 12:02 PM
adam.d's Avatar
adam.d
also worth noting the ICV on an ecotec is the same as an 8v or V6
Old Nov 27, 2008 | 12:11 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
will a 3.2 gsi do it aswell ?? ours occasionally but more usually when the Mrs is driving does it
Old Nov 27, 2008 | 12:21 PM
BigErn's Avatar
BigErn
clean the throttle body and also the above. Should be fine from there.
Old Nov 27, 2008 | 12:32 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
ernie
Old Nov 27, 2008 | 06:06 PM
BigErn's Avatar
BigErn
Throttle body is usually the most common cause, always worth doin first
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
