little end material
nothing to do with sex in any way shape or form, but does anyone know what the material is that little ends are made up from for floating pins ? i.e cosworth ones ?
i know they have phosphur bronze in them but there are other materialsm
and my next question, do we know anyone who makes them to certain specs . i.e i want an O.D of xx.xx and an I.D of xx.xx ?
cheers
cheers
ive got phospur bronze bar but was wondering on its strength when in say a 3mm wall thickness,
Mark, i cant find any berrillium bar to even start making them out of that, might as well be unobtanium,
what about titanium ?
any thoughts
any thoughts
Mark,
When I got all my engine bits together, I realise my pistons were designed to be fully floating as opposed the standard CVH semi floating. I sent the rods and a gudgeon pin back to Farndon and they machined out the rod and inserted a little end bush machined to suit my gudeon pins. Might be worth speaking to them about sorting you some out?
Something I am going to have to do again as I have fucked at least 1 of the rods up.
im guessing at the 3mm wall but wont be far off, im waiting for a rod so i can measure a std cossie rod's small end I.D, the pin is 22mm i want to use, the std cossie pin is 24mm so may be 2mm wall if the std is 1mm wall (usually about 1mm)
how does titanium cope ive got a large ish stash i could have a go at machining up.
If you are only using the new material to make the little end smaller you are not taking away any strength from the rod (the 3mm bit made me think you were opening the rods out
)Aluminium bronze is another alternative ?
Mark
AFAIK titanium is not much good as a bearing surface as it picks up very easily
Mark
Mark
no not removing the rod at all, just to sleeve the gudgeon pin size down 2mm from std cosworth pin size,
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
DavidK
Sep 27, 2015 02:55 PM
