Motorcyle helmets
Old Nov 23, 2008 | 06:27 PM
Magnex20011's Avatar
Magnex20011
Default Motorcyle helmets
Hi Guys
Are all motorcycle helmets the same size on the outside ???? obviously the padding inside varies according to head size? However if you have a big head that would mean less protection if all helmets are a standard size.
Does anyone know the answer?
Old Nov 23, 2008 | 06:34 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
No, the actual polystyrene is the same thickness for all sizes. So all lids are the same strength. the padding really only locates it n your head. Sure, it can absorb a little bit more if you have a tiny head but its debateable whether at 70mph+ it would make any actual difference. Its only sponge after all.
Old Nov 23, 2008 | 06:44 PM
Magnex20011
Default x
sorry rich mate... so ur saying some lids are phyically smaller in size than others???
Old Nov 23, 2008 | 06:50 PM
S1rst's Avatar
S1rst
They are all different sizes mate. I have 3 different road helmets, all the same fitment size, but all slightly different shell sizes.
Old Nov 23, 2008 | 06:52 PM
Maria.'s Avatar
Maria.
They all vary in size!! outside, inside, back to front, inside out
Old Nov 23, 2008 | 06:55 PM
S1rst's Avatar
S1rst
Basically, the thickness of the internal structure is the same as said above, but the shell size varies to suit different head sizes. Its debatable whether larger helmets offer more protection though as the thickness of the internals is the same, but the actual surface area of the internals obviously increase with head size, so in theory, it 'may' spread the impact more effectively if you have a big bonce.
Old Nov 23, 2008 | 06:57 PM
Rs(555)'s Avatar
Rs(555)
ive got 5 motorcycle helmets all the same size but defo different fitment when on my head keep collecting the flippin things
Old Nov 23, 2008 | 08:11 PM
foreigneRS's Avatar
foreigneRS
Testing the future
cheap ones have the same outer shell size for all sizes, meaning that small sizes have more padding on the inside. the downside is that it's more bulky and catches the wind more.
only expensive ones have different shell sizes
Old Nov 23, 2008 | 08:26 PM
Farmer Giles's Avatar
Farmer Giles
there are certainly different shell sizes.
for example one manufacturer might use the same outer shell for their small and medium sizes and then a larger shell for large and extra large sizes and so on..
Old Nov 23, 2008 | 09:34 PM
madsi's Avatar
madsi
thats how arai work it
Jim Galbally
18
Aug 19, 2005 04:50 PM
M7 COS
Jul 11, 2005 03:18 PM
M7 COS
16
May 31, 2005 04:13 PM
Shings
Feb 1, 2005 06:57 AM
