Which Turbo ??
Old Nov 23, 2008 | 01:25 PM
Dearo's Avatar
Dearo
Default Which Turbo ??
Any idea which Turbo the below is ?????
Old Nov 23, 2008 | 01:35 PM
mechanic28's Avatar
mechanic28
not sure is this a rouse cossie?
Old Nov 23, 2008 | 01:49 PM
Dearo's Avatar
Dearo
I bought the engine loose ages ago, so I don't know what vehicle it came out of ??
My friend said that it didn't look like a standard cossie turbo though ???
Old Nov 23, 2008 | 01:54 PM
leejones09's Avatar
leejones09
dont expect to much help mate my topics just got brushed away,there should be a code on the turbo and if you take that code and ring a turbo specialist they should tell you what it is hope this helps
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Looks possibly like a T34 from a Lancia.. well the compressor housing, anyway.
Old Nov 23, 2008 | 02:06 PM
mechanic28's Avatar
mechanic28
does not look like a standard cossie turbo
Old Nov 23, 2008 | 02:40 PM
VEEDUBBED's Avatar
VEEDUBBED
Default Turbo..
That's a Garret T3/4 .60 cold side,.36 or.48 hotside off an '89/90
Lancia delta integrale non cat model.
Old Nov 23, 2008 | 03:17 PM
LHD220Turbo's Avatar
LHD220Turbo
maybe these were fitted to early 3 doors??; as i went to look at a crashed 3 door once and it had the same turbo fitted...
Old Nov 23, 2008 | 03:30 PM
Dearo's Avatar
Dearo
Garret T3/4 .60 cold side,.36 or.48 hotside (Gone right over my head) what does all this mean
Please excuse my obvious lack of knowledge. So is the Lancia turbo any good.
Haven't driven the car yet, so I don't know what it's like ??
Old Nov 23, 2008 | 10:46 PM
Dearo's Avatar
Dearo
Anyone explain these figures to me ??
Old Nov 23, 2008 | 11:41 PM
dox's Avatar
dox
look for the A/R numbers on the housings, if its a t34 of some discription
it should have .48 somewere on the compressor housing and .48 or .55 or .63
in or on the exhaust housing.........it deffently DOES NOT look like any
turbocharger ive seen off a standard YB engine.
if it is a t34 or t3/4 turbo it will be fine for up to a stage 3 application
hope this helps mate
Old Nov 24, 2008 | 11:16 AM
VEEDUBBED's Avatar
VEEDUBBED
Default Turbo..
I've had a few on my Vw corrado turbo and i've
never had any issues,1 thing i did do was to fit a 360 degree
thrust bearing that i bought off eBay for 30 sqids.
I would'nt use the mega small .36 Lancia delta exhaust housing
as it'll choke the engine but will have lightning response!.
Min. i'd use is either a .48 hot side or pref. a .63 jobbie but
you'll notice some more lag compared to the smaller .48.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
