fitting a breather return in the sump
Old Nov 23, 2008 | 09:54 AM
pacwest's Avatar
pacwest
Puller of the Wrench
Default fitting a breather return in the sump
So I don't want to remove the sump. I figure I can drain the oil, clean up the sump, scuff the paint off and rough up the metal and JB Weld the bung in (after drilling).
The sump is not under pressure, JB Weld is perfect for this. Just need a quality fitting that the JB will bond to and a spot on hole drilled.
Anyone else do the same?
Old Nov 23, 2008 | 08:52 PM
Shane C's Avatar
Shane C
Hi,
This was done to my car before i bought it. My only concern would be fillings or oxidizations in the sump, may get into the oil.
Old Nov 23, 2008 | 08:55 PM
pacwest's Avatar
pacwest
Originally Posted by Shane C
Hi,
Drill it. Fill. Drain. Repeat. With cheap oil and swarf of that size it's easy. Swarf of that size won't get sucked into the mesh. Smaller swarf will be caught by the filter.
Old Nov 23, 2008 | 08:58 PM
col cos1's Avatar
col cos1
ava done mine in place with an adaptor to the sump plug to save removing the sump to drill and tap
Old Nov 23, 2008 | 09:01 PM
cossie604's Avatar
cossie604
Heard a rumour that Burton power sell a sump plug designed for the job??
Old Nov 23, 2008 | 09:40 PM
AndyPen's Avatar
AndyPen
Yeah they do - I would still worry about silly bits getting through to my precious engine - I took mine off to do it and fitted hydraulic seals at the same time
Old Nov 23, 2008 | 10:05 PM
pacwest's Avatar
pacwest
Yeah a decent banjo fitting down there would work.
Old Nov 23, 2008 | 10:19 PM
pacwest's Avatar
pacwest
Can't seem to locate the burton kit online. Ring them I suppose?
Old Nov 24, 2008 | 09:20 AM
It's a std thread, so any decent hydraulics place could supply a fitting that will go straight in.
Old Nov 24, 2008 | 09:24 AM
rst in breaking's Avatar
rst in breaking
you can get the standar rst ones from ford for Ł2, worth taking the sump of and doing properly if im honest as it isnt worth ruining an engine???
Old Nov 24, 2008 | 03:11 PM
pacwest's Avatar
pacwest
I'd remove the sump to weld it in -if it's not brass. But considering there are two filters, drills pull swarf out (up) and that you can flush it out, I'm not worried about debris.
I'm wondering about a bung that fits nicely.
RUBY123
Oct 22, 2023 12:04 PM
Gadget
Aug 26, 2015 01:02 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
lockie
Jul 31, 2015 10:03 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
