New L6/L8/P8 Pectel Monitor Software Development
Old Nov 22, 2008 | 01:06 PM
ECU Monitor Enthusiast
Default New L6/L8/P8 Pectel Monitor Software Development
Hello All,
Following on from this thread.... https://passionford.com/forum/showthread.php?t=266269
I will start the story again for those who dont know...
I was going through some old stuff from my old product developments and came across a file I had forgotten about.
A whole load of information regarding weber ecus and in particular pectel versions of those ecu's I have researched in great detail.
This seemed a great waste as I spent alot of time gaining the information and it is just wasted doing nothing.
I found my self with some free time in the evenings and have knocked up this program.
Also, I thought it would be good to develop this openly as to allow people to suggest changes/features as everyone has different needs.
Here is a qucik screen shot so far...
You may down load a demo version here..... http://www.s8ecu.co.uk/FPM_DEMO_211108.zip
(This is a zip file, best create a new folder yourself and run it from this)
Its basically a PC pectel monitor but this program is so much more than that.
This can be used as a diagnostic tool, Data logger, digital dash board, alarm monitor etc...
Also, will have some live mapping features above and beyond what is possible with the standrad pectel type monitor. (Subject for another day)
Also, I intend to add extra intefaces to allow other sensors such as EGT, Speedo etc...
The user can customise the screens exactly as wanted and save the layout to one of 10 storage settings for easy recall.
Each display item can...
1) Be resized by dragging the corners.
2) Be moved by dragging the window title.
3) Turned on or off by selecting them from the displays menu.
4) Change colours by right clicking any item.
5) Enable/disable background image blending (transparancy)
6) Allows a user image to be used as the background
(Put your own JPEG (.jpg) image called BACKGROUND in the same folder)
The scope item cannot be changed much at present as that is what I am working on.
I intend to add other types of graphic functions an displays but the aim first is to get it as a working entity on a car and add new displays and wanted features due to popular demand...lol
Also, I will add other vehicle communications to it such as OBD2 etc...
The program above is a demo program and will not communicate with a car as I have disabled that for now.
When you select the ONLINE fuction, it will simulate some data to show you how it will look when a car is actually connected.
This data simulation is far from perfect but you will get the idea of how it works.
If you try it out and find any bugs or have suggestions for features or modifications the please feel free to comment on this thread.
Please do not email or PM me about this software.
I intend to update this thread every few days for those interested.
When its in a reasonable working state, those who have contributed here may have a copy protected limited version although you will have to make your own interface cable.
I may ask one of our resident loom makers to supply these at a reasonable cost for these people.
I have no idea or plans on how the final software will be published at this point in time but should it ever be comercially available, I will only do this via offical PF traders otherwise, it will be FOC.
*** THE SMALL PRINT ****
I will say now, this is NOT a for sale advert.
I am developing this software at this point purely as something to do.
You may down load it free of charge.
I offer no waranty/guarantee or timescales for completion.
You may down load it at your own risk although I have fully virus checked it.
Enjoy
Last edited by ECU Monitor Enthusiast; Jan 1, 2009 at 09:37 PM. Reason: Spelling...LOL
Old Nov 22, 2008 | 01:30 PM
sortedsaff's Avatar
sortedsaff
This is bang on. followed this from the start .what can i say cant wait to see this finished and will be very interested in the finished result.
Top work
Old Nov 22, 2008 | 01:33 PM
Stu @ M Developments's Avatar
PassionFords Creator
Great project mate. Been following it with interest.
Old Nov 22, 2008 | 01:37 PM
J1mbo's Avatar
J1mbo
B1mbo
this looks good havnt been following the other thread .. may be should have ! so is it just for pectel ecu's or webber ecu's with pectel boards ?
can you explain a wee bit about it as i dont fancy reading the whole other thread lol
Old Nov 22, 2008 | 01:42 PM
hicost's Avatar
hicost
Cosworth 7
Default Software
Looks like a great bit of work, would be nice to have a working version to try, just putting a fresh engine back in the car as we speak.
A good reason to stick with my P8
Well done.
James
Old Nov 22, 2008 | 01:43 PM
kjc300's Avatar
kjc300
Simon,
If you make any of the digi windows really big, the readout flickers. Apart from that really good mate. As jimbo asked above, will this connect via the diagnostic port connection? Any ecu with a pectel board?
Plus is this going to work with your ecu? Can you pm me about that please mate.
Old Nov 22, 2008 | 02:17 PM
hicost's Avatar
hicost
Cosworth 7
Could it have a bluetooth interface / conection, that way it could possibly be viewed on say a Nokia E90 etc.
Just a thought
Old Nov 22, 2008 | 02:24 PM
RUBY123's Avatar
RUBY123
i dont no if it does it at the moment but it would be handy for some sort of warning feature for like voltage drop or high coolant temp and so on
Old Nov 22, 2008 | 03:41 PM
Jimbo,
It will do ALL the pectel monitor does including the mapping version and much more.
It connects via the serial port on the ecu using only 3 wires.
So yes it will work on all pectel boards (if enabled for monitor) and others.
Stu @ MSD can add the pectel monitor data stream to ANY chip with or without a pectel board
Its reads all incoming sensors and fault codes (and much more)
It will data log to the limit of the hardrive.
Plus you can set your own warning limits and alarms like the SECS monitor.
The mapping facility will allow full live mapping just like a modern ecu except its only active while the PC is connected as the L6/L8/P8 doesnt have rewriteable memory but you will end up with a hex file to burn an eprom.
So you can use it as a diagnostic tool and/or digi dash display if you have an old laptop to butcher up for the car.
See above
Just a thought
I hope to have a JAVA version of the program as my next project but will need some kind of interface that will cost money...LOL
Originally Posted by kjc300
Simon,
Kev,
At the moment, the demo version updates the windows too often so will cause flickering on large fonts on slower computers..
The ecu only updates about 5 to 10 times per second normally.
Yes it will work on S8 but I want the pectel version working first as I have a mate who is fitting a PC into his car as we speak an he has an L8.
Drop me a PM if you need info to talk about your car
Old Nov 22, 2008 | 03:46 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
simon, does this connect via the plug stu uses for als/lc? if so can it still be used somehow?
Old Nov 22, 2008 | 03:51 PM
Originally Posted by JTECHSAFF
simon, does this connect via the plug studs uses for als/lc? if so can it still be used somehow?
It connects to pins 8 and 27 which are the diagnostic socket connections.
If these pins have been used for other purposes (E.G 8 injectors on some) the internal connections can still be used but obviously will be harder to get at.
I think MSD's LC/ALS use pins 13 and 14 from memory but I could be wrong. ????
Old Nov 22, 2008 | 03:55 PM
JTECH James
Passion for Fords!
yes pins 13,14. i just assumed you would use that plug.
is there an external plug for your required pins? i cant remember lol.
great product!
Old Nov 22, 2008 | 04:03 PM
There is a 3 pin diagnostic socket on the factory looms near the ecu main plug.
(Its under the bonnet between the batterry and strut top on an escos)
Pins 8, 27 and an ecu earth.
Old Nov 22, 2008 | 04:06 PM
JTECH James
Passion for Fords!
ah, ok.
how will it connect to the computer? usb? most new stuff is usb only now....
Old Nov 22, 2008 | 04:08 PM
It uses RS232 but you can get USB to RS232 interfaces very cheaply for about £10 from most computer shops.
Old Nov 22, 2008 | 04:10 PM
JTECH James
Passion for Fords!
everthings a winner then!
Old Nov 22, 2008 | 04:12 PM
J1mbo's Avatar
J1mbo
B1mbo
thanks for you reply simon this sounds good
and how much will this be in the end ?
jim
Old Nov 22, 2008 | 04:17 PM
pee vee's Avatar
pee vee
Whos car have you tried this out on Si?
just dawned on me that you aint had a cossie for years lol
or can you do it without it being near a car.
Old Nov 22, 2008 | 04:23 PM
foreigneRS's Avatar
foreigneRS
Testing the future
little tip - the connector for the diagnostic socket is the same as the electric window one inisde the door of sierras
Old Nov 22, 2008 | 04:43 PM
jim
J1mbo,
I have no idea what the future of this holds as its just something I wanted to do for fun.
I cant really give a price I think it could be worth as that may break trader rules.
I will let a few tuners/traders have a play first with the full version for some proper feedback
(then wait for the wads of cash to be waved under under my nose...LOL )
I have an L8 and P8 ecu on my engine simulator box as well as an L8 software ecu emmulator.
Also, have a couple of local friends with cossies who have been helping me
Interesting....Thanks !!
Old Nov 22, 2008 | 04:55 PM
J1mbo's Avatar
J1mbo
B1mbo
[quote=Flux Capacitor;3754676]J1mbo,
quote]
great it like to have a play with this ma self
Old Nov 22, 2008 | 04:58 PM
Westy's Avatar
Westy
will this work on my type r lol.. good luck with it all si
Old Nov 22, 2008 | 05:04 PM
Westy,
It will do when the OBD2 functionality is added
Old Nov 23, 2008 | 11:49 AM
mark_24v_wiring's Avatar
mark_24v_wiring
Will be interested in a lead for the obd2 when its ready just to be nosey with my car lol
Old Nov 23, 2008 | 11:57 AM
costina's Avatar
costina
Live long and prosper!!
Fair play to ya Simon looks to be an intersting bit of kit
Paul
Old Nov 23, 2008 | 03:59 PM
Miller 3's Avatar
Miller 3
This done yet? Cant think of anything else to add but im still thinking
Old Nov 23, 2008 | 09:16 PM
LOL, its already working as it is for L8 and P8.
Is your car enabled for data stream ?
Just need to work out how I am going to protect my work for now while giving out working samples for evaluation.
Only takes 1 person to take advantage and I lose control of it !
Most secure protection systems cost money as they use hardware plug in keys or software librarys you have to suscrribe to etc.
May need to spend a time and invent my own security on it !!
Old Nov 23, 2008 | 09:22 PM
JTECH James
Passion for Fords!
simon, how does this differ from the iaw software already out there?
Old Nov 23, 2008 | 09:33 PM
fraser9764's Avatar
fraser9764
the only thing i could notice was that you can't resize the scope? my screen is 800x600 and you struggle to get everything on one screen and still be able to read everything.
Old Nov 23, 2008 | 09:39 PM
I wouldnt know as I have never tried any other IAW stuff myself apart from the original pectel monitor unit.
All this work is my own based on my own experience and designs.
I will say, from my investigations, I have discovered much more of the capabilities of the standard data stream than is used on anything I have seen.
For example, I am able to read the whole contents of the memory including the chip which leads to many new possible functions.
Also, it is possible to alter memory in the ecu ram
Old Nov 23, 2008 | 09:41 PM
I am currently working on the scope functions and you will be able to resize it on the next update.
I wil also be adding default layout functions for different screen sizes.
Old Nov 23, 2008 | 09:46 PM
JTECH James
Passion for Fords!
so if you wanted to run this in car on a screen, what would you need? whats the easiest way? is there a way around having a full pc onboard?
id like it in mine, on a live screen, but i dont want the agro of a pc hidden away,
Old Nov 23, 2008 | 09:57 PM
You can get small single board solid state PC's with screens for about £300.
I have some links on my other computer to these products and will post some up soon.
I have also seen some PCs designed for in car use but they are not cheap !
Having said all that, there are so many cheap second hand lap tops out there as you dont need anything too special to run the software.
I beleive Chip put an old laptop in his boot and used a video head unit as a remote display.
Old Nov 23, 2008 | 10:05 PM
Spiky's Avatar
Spiky
will this work with the pug 306 gti6 or clio 172???
Old Nov 23, 2008 | 10:12 PM
When I add the OBD2 protocol, It will work on any car built after 2000 with a 16 pin OBD connector
Old Nov 23, 2008 | 10:13 PM
Spiky's Avatar
Spiky
bugger wont work with the pug then..lol
and the clio is a 2000 car..lol
Old Nov 23, 2008 | 10:21 PM
Will probably be ok on the clio as they adopted OBD around 1998.
Aiming to get it working on Fords first mate
Old Nov 23, 2008 | 10:29 PM
Miller 3's Avatar
Miller 3
Pass. What dose that entail? i am on a L8' but have no laptop or car monitor as yet.
Old Nov 23, 2008 | 10:32 PM
Probably a question you could ask Stu as its one of his chips.
If it isnt, he can enable it for a small fee with a chip change.
Old Nov 23, 2008 | 10:35 PM
Jay,'s Avatar
Jay,
Sponsor
i love car pc's
