T4 or T34
Old Nov 19, 2008 | 06:58 PM
fezzajsy's Avatar
fezzajsy
Default T4 or T34
which would you recomend for a stage 2 cossie?a mate of mine wants to get rid of his t4 and i wanna buy it or should i get t34 instead?.is a t4 abit of an overkill for stage 2?
any advice appreciated..
Old Nov 19, 2008 | 07:23 PM
Captain500rs's Avatar
Captain500rs
A wud say go for a t34 mate tbh think the t4 wud be overkill if all ya after is stage 2, t4's tend to be really laggy and tend to be used on higher spec engines .im running a t34 on a .48 housing and it spools up nice and quick
Old Nov 19, 2008 | 07:28 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
t34 for a stage 2 with a .48 for quicker response.
Old Nov 19, 2008 | 07:32 PM
fezzajsy's Avatar
fezzajsy
cheeRS for the replies guys..whats the limit on a t34?
Old Nov 19, 2008 | 07:36 PM
Captain500rs
Depends what spec ya running,injectors, exhaust housing ,head work etc,there is a few threads on here mate check in the search at top of page
Old Nov 20, 2008 | 07:00 AM
If you use a T34 .48 with a ar60 compressor 380 very reliably all day long, with next to no lag, preferably with 360 bearing.
Old Nov 20, 2008 | 04:50 PM
Captain500rs
How much are the ar60 compressors and where do ya get them form tab? wud ya say these are better than going the .63 exhaust housing route?
Old Nov 20, 2008 | 05:03 PM
TurboShed's Avatar
TurboShed
Cossiemodo
What do you mean by a Stage 2? It sounds like you would be ok with a T3 if you're not looking for more than 300bhp.
Old Nov 21, 2008 | 07:56 AM
When I say ar60 I am talking compressor housing, this is std on the 4x4 sierra, 2wd had ar.42.
This would still give low down boost with lots of scope for more power, it won't give a big kick like a .63 turbine housing would, because it doesn't have the lag a .63 does to start with so there is less difference between on boost power and off boost power as it is there to start with.
A new .60 ar compressor housing fitted is around £200, I use turbocentre 01924 404112.
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
28
Sep 8, 2015 07:10 PM
