coilpack
Old Nov 3, 2008 | 05:08 PM
cossie0_4's Avatar
cossie0_4
Default coilpack
want to fit coilpack on my saph what parts are needed and when you send you ecu off for it to be modded will you still be able to use your original chip or do you need a remap cheers
Old Nov 3, 2008 | 05:12 PM
cossie0_4's Avatar
cossie0_4
forgot to say its 2wd and l6 ecu cheers
Old Nov 3, 2008 | 05:37 PM
robA's Avatar
robA
Post
http://cgi.ebay.co.uk/Cosworth-Waste...742.m153.l1262
stu at msd sell these , well worth the investment !
there is no need for a remap , wasted spark has nothing to do with your chip.
Regards Rob
Old Nov 3, 2008 | 06:40 PM
cossie0_4's Avatar
cossie0_4
can you get the parts individually as on a budget and could do with getting bit by bit when funds allow cheers
Old Nov 3, 2008 | 07:37 PM
robA's Avatar
robA
Post
i think you can , see other parts for sale in shop
Old Nov 3, 2008 | 07:46 PM
my mate has had this conversion done on his escort cossie. He said his mpg is spot on. He told me it cost him 35 quid to get from the north east of england to santa pod. Dont you have to put a resistor in the rev counter so that it works.
Old Nov 3, 2008 | 07:51 PM
robA's Avatar
robA
Post
Escos i do not know how to mod. the wiring for rev counter , with the saff (4x4)you have to take the dash out and do some mods to the rev counter
Old Nov 3, 2008 | 07:58 PM
cossie0_4's Avatar
cossie0_4
i would be able to fit all the parts apart from any wireing or soldering but sounds like a good conversion as misfires get on my nerves more than anything so will be doing as soon as money allows can you also buy a blank for the dizy if you dont need it cheers
cossie daz's Avatar
cossie daz
ive been thinking this to about coil pack,is it really worth it??
not trying to hijack youre thread
Old Nov 3, 2008 | 08:26 PM
robA's Avatar
robA
Smile
i had misfires on the ford spark plugs , misfires on the ik 31 's , perhaps the problem was in the tdc sensor / dizzy sensor , (these 2 cause misfires as well) or something else , but i fitted the wasted spark system and it runs perfect. starts on the first turn , Hc in the exhaust gasses went down quite a bit . basically the best uprade on the cossie
Old Nov 3, 2008 | 10:22 PM
cossie0_4's Avatar
cossie0_4
did you fit yours yourself or drive in drive out if you did it yourself how much did it cost for the parts
Old Nov 4, 2008 | 06:17 AM
robA's Avatar
robA
Post
More info on the link , and pictures and prices
http://www.motorsport-developments.c...stedspark.html
Old Nov 4, 2008 | 12:20 PM
You can't just junk the dizzy, as it drives the oil pump, and supplies the phase, though the phase signal can be moved elsewhere.
Reyland do a dizzy bit that sits flush with the block and acts just as a oil pump drive then.
It is perfectly possible to high a very high power cossie on std ignition with no misfires if everything is right.
I looked into the conversion but consider myself that is it expensive when compared with aftermarket ecu, that do coilpack plus lots of other stuff, might be best to decide what you wnat in the long term and save for that.
The msd conversion certainly works well though.
Old Nov 4, 2008 | 12:24 PM
robA's Avatar
robA
Post
i have left the dizzy in its place , just take the coil and plug leads out.
Old Nov 4, 2008 | 04:15 PM
KSA-Cossie's Avatar
KSA-Cossie
WELL worth it m8.
Old Nov 4, 2008 | 04:16 PM
I took my dizzy apart, fitted a oilite bush in place of the std ford crushed iron particle one, for total reliability, and whilst at it, machined off in the lathe the end of the shaft where the rotor arm sits, as I had to pull end off to grind off one of the two lobes anyway.
It now sits at the level of the metal surround ring at the base of where the dizzy cap was, made a plywood insert for here and painted black, all sealed up so water can't get in, holes in underside enlarged slightly as well.
bigluke200
14
Sep 2, 2015 10:35 PM
muz
Aug 16, 2015 12:57 PM
marky_g
Aug 15, 2015 10:43 AM
FAST AS FORD
Feb 23, 2006 05:52 AM
Cossie Sean
35
Dec 8, 2005 12:20 PM
