will a series 2 ecu run a s1
Old Oct 30, 2008 | 08:31 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Default will a series 2 ecu run a s1
as above just wondering
Old Oct 30, 2008 | 09:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
yes they are all interchangable
Old Oct 31, 2008 | 08:26 AM
Rick's Avatar
Rick
no it won't unless it's a very early one as it needs a knock sensor or it will retard the ign hugely.
Old Oct 31, 2008 | 10:12 AM
bigryrs's Avatar
bigryrs
RSHoleinator
fook sake ive got a series 1 engine in my series 2 and i just bought a chipped ecu off a s2
Old Oct 31, 2008 | 10:33 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Are you sure mate?
It only retards the ignition if the little piezo mic 'hears' Knocking/Detonation which generates a small voltage and signals the ECU, if it's not connected or isnt present then it cant 'hear' anything, the ECU doesnt receive any voltage (signal), and the timing isnt retarded.
Karlos.
Old Nov 1, 2008 | 05:59 AM
wul young's Avatar
wul young
Default e c u
i have s1 standard ecu m8,just be case of soldering piggyback to board and fittin chip,i can do if you req? would take Ł40 delivered.
Old Nov 1, 2008 | 07:03 AM
bigstee1's Avatar
bigstee1
how much do you want for ya s2 chiped ecu?
Old Nov 1, 2008 | 09:24 AM
bigryrs's Avatar
bigryrs
RSHoleinator
im just gonna change the inlet to a s2 so ive got a knock sensor ive got the s2 inlet in my garage ready to go
Old Nov 1, 2008 | 10:31 AM
Rick's Avatar
Rick
Originally Posted by Karlos G
Are you sure mate?
Karlos.
Doesn't work like that i'm afraid. The ECU interupts no signal as knock as well - it's a real pain, as they often play up and retard for no apparent reason. That's why you can't just disconnect them, and a good mod for the S2 is to put in an S1 ECU, but you can't do it the other way round.
Old Nov 2, 2008 | 06:09 PM
bigryrs's Avatar
bigryrs
RSHoleinator
im a proper muppet i went to change over the ecu's and the one in the car is already chipped by brodie britain racing
JK12
33
Apr 26, 2021 12:09 PM
big_Rad
Sep 15, 2017 09:36 AM
3drRich
Sep 13, 2015 07:32 PM
xrmalin
Sep 13, 2015 06:52 PM
SteveyDee
Aug 25, 2015 07:48 PM
