3dr with a mis fire
Hi lads can anyone put any light on a small problem i have .
what the car has
full motor rebuild
full head reuild
rs 500 intercooler
T34 turbo new
-31
set to give out 20psi
greens new
ally rad new
all the pipes new
3barr
L1 ECU with a chip for all that lot
Right whats hapening is when the car gets to mormal temp and you boot it the turbo cicks in and of it goes but it gets to about 5000rpm and you can feal its holding back a bit and it also back fires and it does not seem to want to rev much past 5000. i just had it out and as i came up to an island i dropped one gear to get the revs up as i came of the island and floored it it rev,d but was back fireing like a machine gun anyone put any light on it
O i do have to confese the car has NOT had a set up on it yet
what the car has
full motor rebuild
full head reuild
rs 500 intercooler
T34 turbo new
-31
greens new
ally rad new
all the pipes new
3barr
plugs are of MATT lewis gap is standerd when we put them in
this is the post i bort the chip of ....3dr Cosworth Level One ECU Chip (made by PTS 330 803, 3 bar, 500 cooler)
crank sensor.. new but will check gap but it was right when i bilt the motor
ignition amp ?????????
dizzy cap/rotor arm ... new
plugs new 700mile but will get some new ones tomorrow
DixieTheKid
11
Jun 6, 2020 11:20 AM
